Results 1 to 7 of 7
    Reputation: parkp81's Avatar
    Shimano XT M785 Brake Leaking from Piston - can this be fixed?
    So I decided today I was bleeding my 2012 M785 XT brakes , and it appears that the fluid is pretty much just seeping out of one of the pistons during the 2nd to last step in the instructions. Guessing the seal behind there is busted or unseated. Have no clue how it just decided to blow out during a simple brake bleed. I even had the yellow bleed block and funnel following Shimano's instructions.
    I hope this brake caliper is repairable, anyone know of how to fix this?
    Not repairable by the home user. Have to send it in.
    Ok, Thanks
    Reputation: PerthMTB's Avatar
    As its un-useable anyway, you could try dismantling it yourself to see if its just a bit of grit or an unseated seal. Not that difficult to take them apart, clean, and re-assemble. Trouble is you can't buy new seals. Have a look at this thread to give you some inspiration - Ever wondered how a hydraulic brake calliper works?
    I have sent it in to be fixed by Shimano under warranty. Should have it back this week, hopefully.
    Cool, thanks for that link. Interesting.
    Ah, didn't realise it was still under warranty. Sending it back is the sensible thing to do then rather than having a go yourself.
    I'm just messing with you
    Reputation: wv_bob's Avatar
    Quote Originally Posted by the-one1 View Post
    ... pulls out list, scratches off Shimano disc brakes ...
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
  1. Shimano Disc Brake M785
    By Once_Upon_A_Time in forum Brake Time
    Last Post: 01-06-2014, 03:53 AM
  2. Replies: 6
    Last Post: 07-14-2013, 11:24 AM
  3. XT-XTR BR-M785 Warranty Brake Leaking Issue
    By GL1 in forum Brake Time
    Last Post: 07-02-2013, 07:19 AM
  4. Stuck Shimano saint brake piston
    By Sleevem1 in forum Brake Time
    Last Post: 11-25-2012, 08:55 AM
  5. Shimano XT M785 piston problem
    By davidwillis in forum Brake Time
    Last Post: 11-18-2012, 02:48 AM
Members who have read this thread: 11
