Results 1 to 5 of 5
    Reputation: mrilo's Avatar
    Shimano XT m775 brakes with Avid G3 Rotors?
    May seem like a basic question, but my Elixirs were making some noises and I like shimano brakes better anyway but was curious if anyone has used the G3 clean sweep rotors with shimano calipers. Or should I just pick up some XT rotors?
    Reputation: oldskoolbiker's Avatar
    Jun 2005
    I haven't done it, but it should work fine.
    You can just mount the XT's using your avid adapters. Don't use the CPS washers with Shimano Brakes though.
    Reputation: bikewrench's Avatar
    Nov 2006
    As long as you space/shim the calipers correctly, you should be fine. I am running 775s w/ Ashima AiRotors and no probs.
    I turn a wrench @ Simplicity Cycles
    http://www.simplicity-cycles.com
    aka bOb
    Reputation: bdundee's Avatar
    I used them with g2 rotors with no problems but if you use the Avid adapters watch for clearance issues. Nothing a dremel or file won't take care of.
    Oct 2012
    i talked to shimano today and they said ya you can, because im running 160 avid clean sweeper-x rotors
