Results 1 to 2 of 2
    hands up who wants to die
    Reputation: rpet's Avatar
    Shimano XT M739 v brake lever... modulation "shim" or "chip"
    I have a right side M739 v lever that has had one of it's modulation spacer/shim/chip things removed (which gives a softer/slower modulation).
    Wondering if anyone has a source to find a replacement with its little screw?
    I was running cable discs but now I'm back to Vs and need a firmer bite from the brake.
    Thanks dudes.
    -rob
    The server is too busy at the moment. Please try again later.
    Did you ever find a source? I'm regretting that I threw mine away a number of years ago and now I need the extra cable pull and reduced leverage to better modulate a front disk on a vintage franken-build
