Page 1 of 2 12 LastLast
Results 1 to 100 of 162
    Shimano xt 8020 4 pistons
    The new 4 piston Shimano looks exactly like the Saint from its shape. Does someone know if there are some improvements versus Saint.
    How does Saint/xt compare to sram 4 piston dh model? Or Formula Curaís with 200 mm disc.
    May 2010
    I just want to know if they addressed the wandering bite point issue that seems to be plaguing shimano brakes
    I think they've had it fixed for a while. My 8000's are working great
    I'm sure the xt's are built with the same tools as the saints. The saints will most likely be moving towards an updated design.
    It's going to be tough to say until they reach consumers in decent numbers but I would assume more power and better modulation than the current design.
    RAKC Industries
    Jan 2017
    Seeing as saint an zee calipers come from the same "mold" thoughts are that the XTs are actually replacing the Zee's or as mentioned updates to Shimano 4 pot brakes are coming.
    And performance is going to be that of current Zee's is whats being said so far.
    Im actually considering getting one of these calipers after the holidays.
    Sent from my SM-G950U using Tapatalk
    Life on a bike doesn't begin till the sun goes down.
    I believe Zee uses the slx levers, which are not servovawe. The initial information was, that current xt handles work with new 4 piston xt caliber, but there will be specific model next to launch. According to my view, the lever piston needs to move more fluid for larger volume of 4 pistons compared to present 2 piston xt levers. Then again, will the new xt handle be only renamed old Saint lever? Caliber itself will be the old Saint, that is for sure. Nice long wait for nothing if those are actually the Saints with XT labels.
    Quote Originally Posted by Nordic09 View Post
    You believe wrong. SLX have servo wave.
    Ok then. Main concern is if it is worthwhile to wait for the 4 piston xt or just buy Saints which are at ok price level right now.
    RAKC Industries
    Jan 2017
    Well if you think about out it, saints are the XTR rank of 4 pot brakes. I dont foresee the new xt 4 pots being better than saints. More like maybe close, or more like zees.
    Fyi zee and saint are like slx and xtr. No bling, less knobs, slightly heavier. Which is why I would expect the new XTs to fall in between somewhere.
    Reputation: Joules's Avatar
    From what I can tell the only real difference (other than cosmetics) is the lever clamp; If you need the thin clamp and iSpec 2, you have to wait. If you can live with the thick clamp and iSpec b, Saints are available now.
    Thx, that would be the level of changes what I thought, beside of the coloring. Anyone know if there has been some improvement in Shimano brakes bleeding lately? They advertise about the one way bleeding, something new or just marketing?
    RAKC Industries
    Jan 2017
    Improvements??? Shimano is already the easiest brakes to bleed by far. Seem to be the same between older m615 m675 etc and be2 m7000/8000. Takes 20 minutes to do both wheels, once every couple years. They dont have the problems like others unless their was a factory assembly/bleed issue which usually fixed by tightening fittings and doing a quick bleed.
    Reputation: NHMB's Avatar
    Aug 2013
    Im curious with this as well...
    Im having a hard time figuring out what brakes I want.
    I want something as light as possible, don't want to brake the bank BUT willing to if I have dependable, reliable, strong, light brakes.
    all from what i've read-
    hope tech E4 are annoying to bleed, takes time and patience but worth it in the end
    Saints are older style and heavy but amazing stopping power
    xt and xtr have the wandering bite point
    guides are having stuck pistons ( i believe thats the issue)
    My other question is- is there a difference between the saints and new xt m8020?
    RAKC Industries
    Jan 2017
    Xt/xtr wondering bite point has been fixed for a year or so now. Some of the versions that did that may be on bikes in warehouses still but doesnt exist on aftermarket brakes anymore.
    And truth be told, it wasnt bad brakes causing it, bad assembly. If you shortened the hose, bleed the brakes and problem gone for many.
    my new trail bike came with slx levers and calipers, are you saying i just have to change the calipers to zee to have full zee brakes? whats beter servowave or without?
    Quote Originally Posted by cfrench View Post
    yes, Zee and SLX levers are the same thing (the old m670 levers, not the new m7000).
    Servowave or not is a matter of preference, but both SLX and Zee have it. XTR race is the only shimano brake that doesn't have servowave as far as I know.
    Nov 2015
    Quote Originally Posted by NHMB View Post
    The Hopes are a different bleed for sure, but definitely not annoying. No syringes or special tools needed. DOT fluid is a bit messier than the mineral oil in Shimano brakes, but bleeding the Tech E4s takes less than 5 minutes once you figure out how they work.
    I had XT m8000 levers matched up to Saint m820 calipers and they required way more maintenance (in the form of fluid top-offs) and didn't feel as nice as the Hopes.
    Professional Slacker
    Saint levers may be different than two-pistion levers, but there's not much difference.
    I have a set of Saint calipers running off XT levers on one bike and another with full Saint, the full Saint is probably a little more powerful, but XT levers and Saint calipers are still pretty damn powerful...there's just no comparison to XT calipers, wwwwaaaaayyyy more power, lever effort is luxuriously low, comfortable and super easy to modulate.
    I've had the XT/Saint setup for 18 or so months, got a great bleed on the first try and haven't had a problem. If you keep having to add fluid, you've got a leak, or you got unlucky while bleeding and have bubbles trapped somewhere that are slowly escaping.
    CN: Just buy the new XT 4-pot calipers if you already have Shimano brakes.
    Class Clown
    Reputation: dundundata's Avatar
    They look like Saint's
    Thanks for the comments. It seem that nowadays it is difficult to find good and reliable brakes. Previously had Avids and other SRAM products with constant need for the bleeding. I'm running the Formula's now, since 6 years and while the reliability is good and brakes are light - the bite feel is not adequate. I believe that the new xt 4 pots will be very good, only disappointing from the weight point of view as a trail brake. Funny that Saint design is quite old and was not considered earlier as a trail brake, but it is a modern trail/enduro brake now according to today's std
    Btw, they say that Formula is inяroducing 4 pot Cura's, which looks interesting too. Decided to wait a bit, what Shimano XT reviews say.
    Reputation: philstone's Avatar
    Mar 2011
    Iíve got 2 pot curaís and really really rate them, thatís having used both M820 and M9020, I prefer the feel which is similar to guides for modulation but shed loads of power and non of the Guide fade (Iíve previously faded Guide RSCs in the Alps - havenít faded the Curas)
    #bleedblackdieevil
    Sheesh! It takes me 20 minutes just to remove the brake from my bike and get the brake lever mounted level on some beater bars and the caliper hanging straight down. Another hour for bleeding (two hours if I screw something up and introduce air into the system), and 20 minutes to remount the brake on my bike. After the bleed, getting the pads adjusted takes more time, so around 2 hours total--per brake.
    On the other hand, it takes me 3-4 hours per XT brake, and I never get a good bleed on the rear--I struggle just to get the rear brake to be usable. And I spill mineral oil everywhere. With the Tech3 E4's, I tend to just drip some DOT fluid from the lever, so not as much spillage.
    I've done two bleeds on the Hope's and around eight bleeds on the XT's.
    Reputation: 006_007's Avatar
    Quote Originally Posted by happyriding View Post
    Dont quit your day job to become a mechanic.
    RAKC Industries
    Jan 2017
    How is that even possible. I can do my shimano brakes in 15-20 minutes. Thats for both brakes.
    Taking off the bike, why??? Absolutely no reason to.
    Problems bleeding rear brake, your letting air in.
    If your bleeding more than once every year or too, you badly messed something up.
    None of this is the fault of the brakes, time and bleeding problems are solely caused by you in this case. Removing and hanging the caliper randomly is your first and biggest mistake.
    Reputation: the_joe's Avatar
    Feb 2017
    The caliper bleed fitting and hose need to be above the caliper pistons in order to purge air out from behind the pistons using gravity. On some bikes this means taking the caliper off for bleeding.
    2008 BMC Fourstroke 19-559 ISO (RIP in peace)
    2017 BMC Speedfox 25-622 ISO
    2017 Salsa Timberjack 40-584 ISO
    Well, because I have such a hard time getting a good bleed, I try to start with the ideal setup for bleeding.
    And I've never done a bleed where air bubbles stopped coming out of the caliper. After using up a bunch of brake fluid, I just decide enough is enough.
    RAKC Industries
    Jan 2017
    If air bubbles keep coming out 4 things are happening:
    Not properly using bleed funnel (it has an oring on it to seal). Must have some fluid in it.
    Lines are not properly sealed at lever or caliper
    Bleeder or hose attachment not sealing correctly at caliper.
    Injecting air with syringe at caliper possible due to reason above.
    Big thing is to make sure you have proper tools. Shimano bleed funnel mainly. You can purchase proper hose and syringe yourself.
    Pos rep makes me sad
    Reputation: dv8zen's Avatar
    Nov 2017
    Random question about Shimano brakes in general: any reason to flush the fluid? Perhaps if you suspect you overheated it and "charred" whatever's in it?
    Feb 2017
    Quote Originally Posted by dv8zen View Post
    I would flush the fluid every 2 years or so. It does get contaminated with grime thru the piston seals, although this happens very slowly. Older fluid will be darker in color because of this. I dont know if the fluid itself breaks down, never experienced that.
    Quote Originally Posted by RAKC Ind View Post
    I think the bleed funnel seals fine--at least there is no leaking. When I screw in the funnel, I can feel the o-ring compress.
    I think that is most likely the cause but it seems coincidental that I see bubbles with both my old XT brakes and my new Hope brakes. I haven't shortened the brakes lines for my Hope brakes.
    The first few times I bled my XT brakes I had some hose that didn't fit very tightly on the bleed nipple and it would blow off if I wasn't careful. But later I found some smaller hose that is very hard to fit over the bleed nipple, and when I finally get the hose seated it is on tight.
    I'm pretty careful with that, and it's the reason I spill so much mineral oil. I draw a syringe full of mineral oil out of a large Shimano container, then I turn the syringe upside down and squeeze the plunger until all the air flows out of the syringe. Then while squeezing the syringe so that oil is flowing out of the end of the tubing, I attach the tubing to the bleed nipple. I then look at the tubing for any trapped air bubbles, and if air bubbles are present I unhook the tubing from the bleed nipple and try again.
    Yep, I've got all that stuff.
    I do it when my brakes start failing, which is about every 6-8 months (XT M785's). The normally red/pink mineral oil looks like coffee when I drain it with a gravity bleed.
    Class Clown
    I just swapped fluid on my Zees after 6 months of use and the fluid still looked good.
    Feb 2017
    I think there is something seriously wrong with your brakes
    You are probably right. I should just replace them as XT's are pretty cheap.
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    The XT BR-M8020, 4pot calipers, are listed at 288Ä pair, and will be available in at least six weeks.
    I will probably get a single caliper and do something like the Magura MT Trail.
    May 2010
    Theoretically moisture can get into the brake system, and with mineral oil brakes like shimano you need to bleed them to get that moisture out because the oil does not absorb the water and it can pool at the caliper and cause issues. Reality is that a properly sealed system will go years without significant moisture build up, but it is better to be safe I suppose.
    Aug 2017
    They said December, anyone know when is actual release date?
    damned rocks...
    Dec 2014
    Quote Originally Posted by Baho View Post
    Already available in Germany:
    https://www.bike-components.de/en/Sh...Brakes-p59683/
    nvphatty
    Guest
    Quote Originally Posted by kpdemello View Post
    Theoretically moisture can get into the brake system, and with mineral oil brakes like shimano you need to bleed them to get that moisture out because the oil does not absorb the water and it can pool at the caliper and cause issues. Reality is that a properly sealed system will go years without significant moisture build up.
    mineral oil is hydrophobic, and therefor does not absorb moisture from the environment ala DOT fluids except for DOT5, but yes in reality a properly sealed system will go multiple years without the need for maintenance.
    Aug 2017
    Quote Originally Posted by Aglo View Post
    LOL I was looking on the site yesterday and they weren't listed...
    Already in my basket.
    Apr 2017
    Ordered from Taiwan, paid 279 shipped for new brake hose (front and rear) to use my XT m8000 levers and M8020 4 piston calipers front and rear to match my 203mm ice rotors. Can wait, shold be here in 10 days.
    Reputation: yeti575inCA's Avatar
    Dec 2011
    Quote Originally Posted by regiobike View Post
    Let us know your ride results please...
    Sent from my SM-G930T using Tapatalk
    WLB
    WLB is offline
    Slow but not stopped
    Reputation: WLB's Avatar
    Was that from mybicycleparts in Taiwan? I just decided to take a chance & ordered a single 8020 caliper. Just built a Hightower with XT's & 180 rotors front & rear. I'm going to put the 4 pot caliper on the front & see how it works. Since these are so new, I figure what are the chances that they are counterfeited yet, though I suppose they will be without warranty since not purchased through official Shimano dealer. But for $105, not a huge gamble. Since Shimano says they are backward compatible with XT8000, should just bolt up to the banjo & away I go (all the snow we're getting aside)
    Apr 2017
    Quote Originally Posted by WLB View Post
    Yes I ordered from them. For I was reading I need to replace the banjo cause is in different location and is longer. Maybe I'm wrong.
    I'm almost 230 pounds so having front and rear makes me feel safer. My m8000 are nice with the 203mm, we will see with the 4 pistons setup.
    Enviado desde mi SAMSUNG-SM-N910A mediante Tapatalk
    WLB
    WLB is offline
    You may be right on that. I saw this: The M8020 brake caliper is compatible with the existing XT M8000 brake lever. & figured that you could just swap the caliper, but looking at the pictures, the banjo is definitely in a different position & a different length. I guess I'll see when it gets here, or maybe I'll email the vendor & see if they know
    Apr 2017
    They told me that I need the combo Soni ordered from them 2, $35 complete hose and banjo.
    WLB
    WLB is offline
    Found this on the Shimano site, seems to indicate that the 8000 banjo might work
    WLB
    WLB is offline
    Thanks, I'll go back on their site & look for it
    Apr 2017
    That will be nice!!!
    WLB
    WLB is offline
    After doing some more digging around, it appears that while the banjo is the same, the banjo bolt is different on the XT8000 vs the XT8020 calipers. The XT banjo bolt is chrome, considerably longer & goes in across the caliper. The XT8020 4 pot caliper uses the same banjo bolt as the Saint, which is black & shorter. I was able to get just the bolt from Jenson cycles in the US for $3.99, so should be able to leave my existing XT hose w/banjo on & just swap calipers
    Feb 2014
    Might as well order the saint caliper if you have to change the banjo bolt / saint caliper
    WLB
    WLB is offline
    Quote Originally Posted by royocram View Post
    Well, I suppose I could, to be honest the new XT 4 piston looks a lot like Saints, but I want the XT version. The Saint banjo is longer & looks like brass instead of aluminum, but I don't think the XT banjo will be an issue with the correct bolt. Since I already have M8000 XT's on the bike, I wanted to try out the new 4 piston XT caliper
    it's gold-anodized aluminum (to match the little bits of gold elsewhere in Saint), def not brass.
    WLB
    WLB is offline
    Quote Originally Posted by Joules View Post
    Cool, thanks. I read a blurb somewhere that the longer banjo was supposed to dissipate heat better, but if they are the same materials I doubt there would be any real difference in practical use on a trail bike. Maybe a DH rig doing laps, but that's not what I'm doing
    Dec 2011
    Following , let us know how ot works out and what parts you needed to adapt to m8000
    Class Clown
    Anyone try these? They look good but I am thinking about ordering a backup set of Zee's. You get alot of brake for the money. I haven't had any issues bleeding them. Haven't had the pump up issue either and temps are getting low. 15F ride this morning, probably 5F tomorrow so that will be a good test (of my sanity). I use the metal finned pads and after 6 months of riding they still had a little meat left, though I did replace.
    Update: Ok I did notice something. Bike was stored in basement and it got down to 0F. Went out for ride at 5F. Not sure if you'd call it pump up, more like slow down. I'm guessing the fluid got less fluid at those temps. It wasn't a big issue really and was generally consistent. Brakes still worked fine.
    Feb 2014
    Just ordered a saint caliper and a banjo bolt to try if it works with a xt m8000 lever and hose will updat once its installed
    WLB
    WLB is offline
    Cool, still waiting on my caliper. Tracking shows itís cleared customs, hopefully here this week
    Apr 2017
    Mine will be here and installed tomorrow.
    WLB
    WLB is offline
    Nice, hopefully get mine on in a day or two & head down to southern Utah to ride St George area for a few days
    Apr 2017
    Installing the brakes.
    Dec 2011
    Nice! Now we need your thoughts on performance?
    Apr 2017
    Quote Originally Posted by yeti575inCA View Post
    For a 230 pound guy def. I will see if there any lol.
    Apr 2017
    Will try to upload more pics
    Apr 2017
    More
    Apr 2017
    Done
    Dec 2011
    What hose and banjo bolt did you use?
  67. #67
    Apr 2017
    Ordered the Shimano SM-BH90-SBLS hose kit too
  68. #68
    WLB
    WLB is offline
    Ok, I can confirm that the XT M8020 caliper will work with XT M8000 (regular XT) hose & banjo. You just need the Saint style banjo bolt. Mine arrived today & I swapped the front caliper out. Couldnít find my tubing to fit the bleed nipple, so just did a quick gravity bleed from the top using the funnel. Did a few quick runs to start bedding in up & down my street, & everything seems great so far, but havenít had a chance to really ride yet. Gonna hit SW Utah next week & give it a good test
  69. #69
    Apr 2017
    Nice, tomorrow I will go to my local Enduro field so we will see.
  70. #70
    Dec 2011
    Wonder if it warrants replacing 9020 Trail calipers...?
  71. #71
    RAKC Industries
    Jan 2017
    9020 has no more power than standard XTs. XTR is just about weight and trail levers have better modulation.
    If your looking for more power then yes it would make a difference, or they could be overkill for what you ride.
    Nice thing about these, saint and zee brakes have tanked in price, all for what, a re-labeled Zee/saint caliper.
    Makes me happy, can afford 4 pot brakes for my plus bike now, aka zee or saints
  72. #72
    WLB
    WLB is offline
    You're right, they do look just like Zee's. Not sure if it's the exact same mold, or if there are any internal differences. I just kinda wanted to match the XT on the rest of the bike. I got this one for $105 with resin pads & free shipping. You can find Zee calipers for under $70USD, so definitely a better value. As mentioned above, I used the same XT hose & lever, just used a Saint/Zee banjo bolt.
  73. #73
    Actually the race levers are the ones considered to have better modulations since they lack servo wave all other Shimano's have.
    Tallboy 3.1
    OG Ripley v2
  74. #74
    Apr 2017
    Well, tested this brake under heavy breaking downhill track, for about 6 miles. Really impressive, I really like the modulation, feels safest to brake, and don't feel too sensitive like the normal m8000. Hard to explain but the 8020 for me and my weight works much better. The travel of the lever is nice, progressive. Also the bike looks niceee lol
  75. #75
    WLB
    WLB is offline
    Sweet, and nice pics, looks like a beautiful place to ride
  76. #76
    Dec 2011
    Thanks congrats..
  77. #77
    RAKC Industries
    Jan 2017
    Quote Originally Posted by TwoTone View Post
    Yeap I got them mixed up, thanks for correcting that. The trails being the blingy XTs, race the better modulation.
  78. #78
    Dec 2011
    Who has these calipers in stock to order?
    Didnt see on jenson or universalcycles
  79. #79
    Apr 2017
    this is the seller who sent me the hose kit and the brakes calipers:
    https://www.ebay.com/itm/Shimano-Deo...53.m2749.l2649
    and
    https://www.ebay.com/itm/Shimano-SM-...53.m2749.l2649
  80. #80
    Dec 2011
    and
    Thanks... does it come with brake pads? Are they new style brake pads or standard ice techs?
  81. #81
    WLB
    WLB is offline
    Got mine from the same place, took about 10 days from order to delivery. I got the Saint banjo bolt from Jenson, but you can get it from this place as well
  82. #82
    Dec 2011
    Yeti SB4.5C
    AMS aka all mountain systems..
  83. #83
    Reputation: flipnidaho's Avatar
    Looking at price.of just Saint calipers 99.00, wonder idoney is better spent there. Given they are about the same price..
    I run Saint calipers (with XTR Race Levers). If Saint is close in price, go with Saint calipers.
  84. #84
    Feb 2014
    Did you have to change the mount adapter from one caliper to the other?
  85. #85
    Apr 2017
    Bolt on design
  86. #86
    Dec 2015
    Does those got the pumping up issues? Are the levers the same?
  87. #87
    Apr 2017
    Quote Originally Posted by cycloholic View Post
    I used my XT m8000 levers without any problem. Also no pumping issues
  88. #88
    mtbr super member
    Reputation: Biffard's Avatar
    Nov 2008
    Do you feel the M8020 calipers have any impact to the bite of the M8000 levers? Meaning, does it still have that on/off feeling or does it feel more gradual?
  89. #89
    Apr 2017
    Quote Originally Posted by Biffard View Post
    More gradual which is what I like the most, I hate the hard bite of the XT due my riding style. On downhill feels more safe and smooth.
  90. #90
    mtbr super member
    Nov 2008
    Thanks for the feedback! Also curious if you have noticed a difference in stopping power? I think shimano claims the M8020 are 20% more powerful. Is it very noticeable to you under hard braking?
    There are two trails I ride where a little more braking power would be nice so I'm trying to determine if swapping to the M8020 calipers is the way to go since I already have the M8000 sets on my bike.
  91. #91
    Apr 2017
    Yes I feel more power, it's less noticiable bucause is more gradual, but if you apply all braking power you will feel it. Hard to explain. Love how the brake works under downhill tracks
  92. #92
    Dec 2011
    Anyone know what caliper m8020 weight is vs Saints?
  93. #93
    Class Clown
    With just a partial pull of the lever you can feel and hear those metal finned pads contacting the rotor. Such a nice feeling. If you need more brake it is there waiting. They can really bite down. You can lockup wheels if you want to. The future is now.
  94. #94
    Quote Originally Posted by dundundata View Post
    The future is now.
    The future was back in 2000, it just took Shimano 18 years to bring XT brakes back up to par again.
  95. #95
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    One reason is to work out all the bubbles from the opposite side of the brake caliper, especially for the rear brake, at the very least, you should turn the bike vertical in the stand and preposition the lever to horizontal.
  96. #96
    RAKC Industries
    Jan 2017
    I have literally never had that problem with any brakes/bike. Bleeder is at the high point. Air getting trapped is difficult to accomplish unless caliper is empty in which case its already off the bike. My methods negate the possibility of that. If using the syringe method for bleeding then its not a problem (how I do it, but I push and pull to make sure 0 possibility of air).
    Not everyone does but unless system was opened there would be no air to begin with unless person injected air into the system. Thats why removing it makes no sense to me, never had that issue, pretty difficult to create the problem IMHO.
  97. #97
    nvphatty
    Guest
    exactly.
  98. #98
    Apr 2017
    After a week of testing I will not be back to M8000, the transition bite of the 8020 is just perfect. Just love it.
  99. #99
    RAKC Industries
    Jan 2017
    Not getting too much bite in the rear?
  100. #100
    nvphatty
    Guest
    great to hear.
  1. 2year old Shimano XT Brakes- shattered ceramic pistons
    By mojojojoaf in forum Brake Time
    Last Post: 06-18-2016, 07:01 AM
  2. Resetting Shimano ceramic pistons
    By Aresab in forum Brake Time
    Last Post: 08-22-2015, 01:43 PM
  3. XT 8000 or 8020 Front Derailleur for Converted 3x XT Crankset
    By Markiel in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-29-2015, 02:46 AM
  4. Replies: 4
    Last Post: 11-17-2014, 03:12 PM
  5. has anyone tried surface grinding 8020?
    By JaquesN in forum Frame Building
    Last Post: 08-13-2013, 03:07 PM
Members who have read this thread: 676
