Results 1 to 25 of 25
    turtles make me hot
    Reputation: NYrr496's Avatar
    Shimano SLX ... WOW!
    Since '08 when I bought my first bike with hydraulic discs, I've had Avids.
    Juicy 7's, Juicy threes, Elixirs...
    Not had any trouble with any of them.
    While shopping parts for my wife's bike, I couldn't ignore all of the posts I read on here about people raving about XT and SLX brakes.
    I put a set on my wife's Spearfish and I have to say I'm blown away. I love how they feel and I love the lever.
    The only thing I'm not completely thrilled with is the gigantic mount. It kinda limits the way I like to set up the cockpit.
    I think I may try a set on my next build instead of the Elixir Trail 9's I was planning on going with.
    I like turtles
    Reputation: shenny88's Avatar
    Nice, I've been thoroughly enjoying my SLX brakes on my Superfly and even my Deores on my SS.
    Merendon Junkie
    Reputation: abelfonseca's Avatar
    Dec 2011
    Quote Originally Posted by shenny88 View Post
    Can you feel a difference between the deores and the slx on the trail?
    Honestly, while im riding i dont think i can tell the difference in which brake im squeezing. They both stop well and have excellent control. I can tell a bigger difference since the SLX equipped bike has a 180mm rotor on the front and the Deore bike is a 160mm.
    Reputation: PerthMTB's Avatar
    You know the SLX are I-spec compatible, which means you can combine brake lever and shifter on one mount? Makes for a much neater cockpit setup...
    turtles make me hot
    Quote Originally Posted by PerthMTB View Post
    Yeah... But for Shimano shifters, right? I put Sram X7 on this bike.
    I like turtles
    ٩(͡๏̯͡๏)۶[$̲̅(̲̅ιοο̲̅)$]
    Reputation: MondoRides's Avatar
    Quote Originally Posted by NYrr496 View Post
    Try these...
    Problem Solvers
    Using them to match up my Shimano Zee brake levers with SRAM X9 shifters. Nice clean setup.
    BLAH BLAH
    Quote Originally Posted by MondoRides View Post
    Try these...
    Problem Solvers
    I got a set of these hoping for magic, but they just didnt work for how I like my controls set up. They put the shifter to far in for me, though I run brakes quite inboard.
    Whats this line for?
    turtles make me hot
    Try these...
    Problem Solvers
    I saw those. My brakes are too new. 2013. Thanks, though.
    I like turtles
    Pretty sure the 2013 Shimano brakes are also i-Spec compatible too.
    Merendon Junkie
    Dec 2011
    Has anybody else experienced that the factory bleed is not that good? I just bled mine and the braking power and feel improved very significantly.
    turtles make me hot
    I will try them then.
    I like turtles
    Never trust a fart
    Reputation: frdfandc's Avatar
    Love my SLX brakes. Switched from Juicy 7's. Huge improvement.
    turtles make me hot
    Quote Originally Posted by frdfandc View Post
    I currently have Juicy 7's on my bike and I just ordered SLX's for it.
    I like turtles
    Want to sell me your Juicy's? I hate my SLX.
    turtles make me hot
    Quote Originally Posted by TonyB. View Post
    They're from 08 and they're pretty ugly... You may want to rethink that.
    I like turtles
    Reputation: Mr. Chiching's Avatar
    Aug 2013
    are all SLX model I-spec compatible?
    mine is BL M666.
    can i pair any I-spec shifter wid my SLX brake lever?
    many thanks
    mine is BL M666.
    Only M666 and after are I-Spec compatible, so that's M666, M675, and M675-B. But note that the M675-B levers have the new 2014 I-Spec interface, hence the 'B' in the model number, and will only take 'B' model I-Spec shifters.
    M666 levers will fit any I-Spec first generation or I-Spec second generation 'B' shifters - SLX, XT, or XTR.
    Note: This whole I-Spec first generation and new 'B' generation thing is very confusing. What I've said above is correct, but if you want to delve into it a bit more then take a look at this thread - XT brakes with i-spec shifters It's about XT but the info later on about the new I-Spec standard applies equally to SLX.
    May 2005
    Tonyb, what do you hate about your brakes? I despise Avid juicy brakes.
    I had a heck of a time getting my SLX brakes to stop squealing. The power is OK, but I don't like the feel. The modulation is not as nice. My first experience with disc brakes was when I retrofitted a set of Juicy 7's onto a Gary Fisher Tassajara. I bolted them on, aligned the calipers and they worked well and never made noise. Guess I'm in the minority around here.
    Aug 2013
    That's great news! Thank you very much for the comprehensive info Sir. Will look for a compatible I-Spec shifter this weekend, another good motivation coming up
    Re: Shimano SLX ... WOW!
    Must be on some crap rotors.
    I had my m596s on clean sweep g3s 185/160 and my brakes felt okay at best, switched to SLX 180/160 and butter, great modulation and stopping force.
    Sent from my HTC EVO LTE
    Aug 2013
    Got my Xt I-Spec shifters installed to my SLX brake lever already and It's COOL!
    Thanks PerthMTB!
    Just upgrade from elixir 1 to slx m675,...yes slx is wow..
    the modulation, quiet, power , feel, all much better. I dont hv any problem with my elixir 1, just craving for upgrade.
    Happy with my slx..
    btw, anyone know what kind of pads these slx m675 come with?
    Merendon Junkie
    Dec 2011
    These are amazon links to the pads current slx brakes are using. You can have them finned or unfinned. Finned pads look nice but im not sure if you actually need them if your not doing extreme downhill or weigh above 200 lbs and do lots of steep descents. I do lots of steep descents (1500 meters in 12 kms) and weigh 170 lbs. I have used both finned and unfinned with no noticeable differerence.
    Amazon.com: Shimano BR-M985 F01A Resin Disc Brake Pad with Spring and Fin: Sports & Outdoors
    Amazon.com: Shimano BR-M985 G01A Resin Disc Brake Pad: Sports & Outdoors
  1. Replies: 63
    Last Post: 12-06-2015, 07:01 AM
  2. Replies: 11
    Last Post: 06-03-2013, 09:08 AM
  3. Shimano shoe and shimano pedal compatibility issue
    By Christopher Robin in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-02-2012, 06:00 AM
  4. Replies: 37
    Last Post: 07-01-2012, 09:11 AM
  5. Shimano M475 vs Shimano HB RM65 rims on Rock Shox Dart 3?
    By pingzingr in forum Wheels and Tires
    Last Post: 07-18-2011, 10:25 PM
