Results 1 to 5 of 5
    Reputation: Techspec360's Avatar
    Shimano Saints M820 Caliper Leak
    Anyone experiencing this with me? Hydraulic oil leaking from bleeder nipple center port. This brake set is less than a month (only 2 rides, 20 miles) old. Purchased brand new as a set from CRC.
    Brake caliper bleeder nipple fitting leaking. Fluid is leaking through bleeder fitting center "bleed" hole. Fitting has been tightened and properly torqued to 6Nm, still leaking during a ride. Brake lever will "sink" and "pump up" during ride. Second ride on these, performed re-bleed and tightened bleeder a bit more and still leaks through center bleed port (not around threads). Front caliper has same issue. Possible machining or alignment issue preventing complete seal of bleeder to caliper chamfer....?
    These brakes only have 20 miles on them, they are only about a month since installed. They work great until the fluid begins seeping during the ride, then the lever becomes low and inconsistent. However, now the rear pads have become contaminated from the leaking oil and stopping power is greatly reduced, to an unsafe rate.
    https://www.youtube.com/watch?v=mzv16yiBpNc
    Shimano Saint M820 Caliper Bleeder Leaking
    New brake set purchased from Chain Reaction Cycles a few weeks ago, only two rides totaling 20 miles. Caliper bleed screw leaking from center port. Brake lev...
    https://www.youtube.com/watch?v=9hYf8KJD-Wg
    Shimano Saint Caliper Bleeder Leaking
    Front Caliper also leaking (see description from previous video)
    Apr 2017
    Ive got a thread 3 rows down, brand new pair, also having problems. I havnt noticed a leak but my rear has no power. Mine were from Jenson.
    Aug 2015
    Try tightening nipple a little more, if it wont stop just warrant them and get a new pair.
    Quote Originally Posted by mtbfree View Post
    I did try going a bit further along with working it in and out in the seat to attempt to work off any burrs or inconsistency, still leaking. These are going back to CRC. Needed brakes for the race this weekend so had no choice but to go out and buy another set, opted for the Hope E4's.
    Reputation: BigHit-Maniac's Avatar
    Quote Originally Posted by ZacMD View Post
    My rear Saind M820 is low on power too.... tbh... Whats the fix? Bad bleed?
    You in Oklahoma City? If yes, come ride with us.
  1. XTR m965 caliper to Saint m820 lever
    By Forkyu in forum Brake Time
    Last Post: 03-13-2017, 10:03 PM
  2. Saints m820 pads in Hope M4/Shimano M755?
    By the-one1 in forum Brake Time
    Last Post: 10-05-2015, 02:04 PM
  3. M820 Saint Caliper w/ XTR M9000 Levers
    By mopes in forum Brake Time
    Last Post: 02-02-2015, 01:13 PM
  4. Replies: 3
    Last Post: 11-25-2013, 03:37 AM
  5. Replies: 12
    Last Post: 08-19-2013, 10:33 AM
Members who have read this thread: 4
