Results 1 to 6 of 6
    Shimano rotors and Avid Elixir calipers
    Got a new bike that has Avid Elixir 7 calipers running on Avid HS1 rotors. However the front is only a 160mm and as I am a bit of a porker the 160mm feels a bit underpowered. I have a 180mm Shimano RT76 rotor this one Shimano rotor and I was wondering if the Elixir is compatible with the Shimano rotor. I cant see it being a problem but just wanted to check with the Shimano rotor being a different design to the Avid rotor. The fork is a 29er Rockshox SID RL post mount.
    turtles make me hot
    Reputation: NYrr496's Avatar
    I have Shimano SLX brakes on Avid Clean Sweep rotors on my wife's bike. Works perfectly. I don't see why you'd have any trouble with your combo.
    I like turtles
    Got everything set up with the 180mm Shimano RT76 rotor and its fine plenty of clearance for the rivets and alu spider. I also tried a 160mm Shimano RT76 rotor on the back but that doesnt work the spider catches the bottom of the caliper.
    turtles make me hot
    See? Just takes a little trial and error.
    I like turtles
    Reputation: Joules's Avatar
    if only there was a thread that addressed this... maybe the mods could sticky it; the search function does kind of suck...
    Reputation: Kiwiplague's Avatar
    Quote Originally Posted by Joules View Post
    You mean like this one? - Using Shimano Centerlock (or any other) rotors with another brand caliper
    I don't crash, I just have slightly uncontrolled dismounts!
  1. magura rotors to avid calipers
    By blachdude in forum Brake Time
    Last Post: 06-24-2012, 11:14 AM
  2. Replies: 9
    Last Post: 06-14-2011, 08:26 AM
  3. Avid calipers and 180 rotors...
    By thomllama in forum Brake Time
    Last Post: 04-12-2011, 11:28 AM
  4. hope calipers with avid rotors
    By dwyooaj in forum Brake Time
    Last Post: 01-25-2011, 06:36 AM
