    Shimano M785 brakes compatible with hayes 160mm adapters & hayes rotors?
    I'm going to swap out my old hayes 9's with some M785 XT disc brakes, the set I'm thinking about getting do not come with rotors or adapters. Will my Hayes Discs and adapters be compatible with the calipers?
    Just curious.
    Feb 2012
    Your adapters should be good, but I know Shimano's brake pads are picky when it comes to other rotors. Ensure that the braking track of the rotor will be sufficient for the brake pads.
    Reputation: mtbnozpikr's Avatar
    Quote Originally Posted by WacoKid View Post
    Just as he said, adapters are adapters and as long as you are sticking with the same size rotor, you will be fine. As for the rotors, they might but a set of Shimano rotors won't cost too much, especially if you go with 160mm.
    2012 Intense M9
    2012 Pivot Mach 5.7 Carbon
    2008 Look 595
    2007 Custom Litespeed Sewanee
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    Quote Originally Posted by eshew View Post
    Just curious.
    Did the rotors work out just fine? Would think that they would but want to cover my bases.
    Raised in a Chicken-Coop by Chickens
