Results 1 to 5 of 5
    Reputation: ikarus189's Avatar
    Shimano lever stiction?
    Hello all, figured I would see if anyone else is having this problem...got new 2013 Shimano XT brakesets, but the levers are not a smooth pull...seems to be a little hump to get over at the very beginning of the stroke, similar to stiction with air forks...anyone else had this problem and/or fixed it? Both have been bled, and feel solid otherwise.
    Oct 2012
    I think it's the servo wave levers that you're feeling. They have a different pull profile that gives a lot of power in a short stroke at the beginning followed by a more linear profile pull at the end. Hope this helps.
    Apr 2005
    Yes. It's not a bug. It's a feature.
    When I first installed my XT brakes, they would make an audible snap when I pulled the lever back and the pads jumped to the rotor. The sound seems to have gone away after some use, but the feel is still there. They go from disengaged to on-the-rotor very quickly at the beginning of the pull.
    Justin
    Salt Lake City
    2012 Specialized Stumpjumper FSR Comp 29
    2006 Specialized Allez Expert Double
    Quote Originally Posted by ehwik View Post
    that is definitely what it feels like. thanks!
    Oct 2012
    no problem, it takes a bit of getting used to (at least it did for me) as it removes a bit of the modulation by quickening the stroke.
  1. Replies: 7
    Last Post: 03-20-2013, 06:47 AM
  2. Shimano Lever and Caliper?
    By bikeguy27 in forum Brake Time
    Last Post: 07-21-2012, 11:46 AM
  3. Shimano XT: Lever collapses to the bar
    By JonathanGennick in forum Brake Time
    Last Post: 06-26-2012, 07:41 PM
  4. New Shimano SLX 666 lever throw distance?
    By dragbike in forum Brake Time
    Last Post: 06-09-2012, 06:23 PM
  5. Shimano XTR Disc - Lever Does Not Return
    By harshcore in forum Brake Time
    Last Post: 03-31-2011, 12:28 PM
