Results 1 to 14 of 14
    bt
    bt is offline
    Nov 2007
    Shimano I-Spec integrated mount for shifter/brake levers
    anyone know if it is at all possible to use this for the SL-M970 XTR 9spd Shift Lever?
    Reputation: cant fix a flat's Avatar
    You can do, but you will have to do a little grinding on the cover. To make clearance for the lever arm. The 9spd covers are aluminum, not plastic like the 10spd covers.
    <a href="http://smg.photobucket.com/albums/v714/hoyee/?action=view&amp;current=IMG_1918.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v714/hoyee/IMG_1918.jpg" border="0" alt="Photobucket"></a>
    <a href="http://smg.photobucket.com/albums/v714/hoyee/?action=view&amp;current=IMG_1919.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v714/hoyee/IMG_1919.jpg" border="0" alt="Photobucket"></a>
    <a href="http://smg.photobucket.com/albums/v714/hoyee/?action=view&amp;current=IMG_1920.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v714/hoyee/IMG_1920.jpg" border="0" alt="Photobucket"></a>
    bt
    bt is offline
    Nov 2007
    cool, any other details? would you do it again? would you do it differently if you did it again?
    match as best as you can where you want the shifter to sit. then test fit alot. the only thing i would do differently is know where you want your shifter to be. for me, i didnt need to grind as much as i did. also pick up some grey and black model/hobby paint to cover up the grind marks.
    bt
    bt is offline
    Nov 2007
    any pics of the cover after grind?
    sorry no pictures after the grind. only after repainted.
    bt
    bt is offline
    Nov 2007
    cool, so you only use the aluminum arm and not the cover that it comes with, correct?
    and then you adapt the arm to your existing 9speed cover?
    Is it possible to grind material off the arm instead of the cover?
    @trailgrinder
    Reputation: Live2rideUtah's Avatar
    Great job, and some great tips
    Quote Originally Posted by bt View Post
    yes only the arm not the cover and yes adapt it to the 9spd cover.
    you can grind the arm. to me, your grinding away the strength of the arm. there is less material on the cover, which makes it alot easier to grind.
    Quote Originally Posted by Live2rideUtah View Post
    thank you
    Steel and teeth.
    Reputation: b1umb0y's Avatar
    Feb 2005
    Where exactly do you need to grind?
    Thanks,
    d./
    ill try to get some pictures up tomorrow.
    the area in white is where you need to start grinding.
    this picture gives an over view idea where arm sits on the cover.
    this picture is a side by side of the 9spd cover (on the right) and the 10 spd cover (on the left).
    if you are going to attempt this, grind off alittle alittle at a time and test fit alot. take your time doing this. I used a demel with a small cut off wheel and a small box file to clean everything up. i hope this information helps.
    Steel and teeth.
    Feb 2005
    Awesome! Thanks!
    d./
