    Mulleticious
    Reputation: BigwheelsRbest's Avatar
    Which Shimano disc brake brackets / adaptors?
    I need to install Shimano XTR trail brakes (M985) onto, at the front, a new Fox Float 34 fork, and at the back, a Santa Cruz Tallboy LT frame. I am using 180mm Ice-Tech rotors.
    Could someone please tell me what type (model number) of Shimano disc brake brackets / adaptors I need?
    Reputation: likeaboss's Avatar
    On the front you should use Shimano 180 P/P adapters. Not sure about the rear. I replaced Avid Elixir 5s and the Avid adapter worked fine for my 160mm rear rotors.
    Shimano SM-MA90-R180 P/P Disc Brake Adapter from BikeBling.com
    wyrd bi ful rd
    Reputation: chinaman's Avatar
    Something like this
    For the front
    Shimano XTR Mount Adaptor Front Post 180mm | Buy Online | ChainReactionCycles.com
    Rear
    Shimano Mount Adaptor Rear Post to IS 180mm | Buy Online | ChainReactionCycles.com
    Assuming your fork has a Post Mount and your frame has an IS mount.
    Mulleticious
    Thanks.
    Glad I asked - I would have ordered the wrong ones
