Results 1 to 31 of 31
    Reputation: Cenzobear's Avatar
    Oct 2012
    Shimano Deore: Hidden Gem?
    About a month ago my Tektro hydros started leaking on me. I had the caliper warrantied, and two weeks later, same problem. Needless to say, it was time for an upgrade. I saw these M596 Deores on chain reaction for $57, thats about $5 above cost! So I jumped right on them, and liked 'em so much I thought I'd write a little review...
    They came in a big snazzy Shimano box, and contrary to what CRC said, they did include all hardware, bleed, block, hose clamp, and even an olive and barb,
    <a href="http://www.flickr.com/photos/reyzo14/8635940186/" title="_DSC0990 by CenzoBear, on Flickr"><img src="http://farm9.staticflickr.com/8116/8635940186_906c158088_z.jpg" width="640" height="425" alt="_DSC0990"></a>
    <a href="http://www.flickr.com/photos/reyzo14/8634833139/" title="_DSC0992 by CenzoBear, on Flickr"><img src="http://farm9.staticflickr.com/8264/8634833139_3a4050b5d8_z.jpg" width="640" height="425" alt="_DSC0992"></a>
    The master cylinder was a lot nicer than I expected. I mean a lot, for 57 bones you get the new cylinder design, adjustable lever reach, servo wave technology, and a super easy bleed process. It's essentially an SLX lever:
    <a href="http://www.flickr.com/photos/reyzo14/8634841421/" title="_DSC1012 by CenzoBear, on Flickr"><img src="http://farm9.staticflickr.com/8383/8634841421_cbec2f95a6_z.jpg" width="640" height="425" alt="_DSC1012"></a>
    <a href="http://www.flickr.com/photos/reyzo14/8635944632/" title="_DSC0993 by CenzoBear, on Flickr"><img src="http://farm9.staticflickr.com/8520/8635944632_09a5eaa819_z.jpg" width="640" height="425" alt="_DSC0993"></a>
    The Caliper, however, is a little less awe inspiring. From the side it looks like a no-name black caliper. It looks to be very similar to the las gen Deore M595. The inboard face does have the model number stamped on, and the top has the Shimano Deore logo. It uses Shimano's metal pistons, and uses in line hoses rather than the thru-bolt banjo design of higher end stoppers.The top loading pads are a nice touch, although not center mounted, so Ice Tech pads can't be used.(Surprise!) Organics come stock.
    <a href="http://www.flickr.com/photos/reyzo14/8637220945/" title="_DSC0968 by CenzoBear, on Flickr"><img src="http://farm9.staticflickr.com/8256/8637220945_0915feb235_z.jpg" width="640" height="425" alt="_DSC0968"></a>
    <a href="http://www.flickr.com/photos/reyzo14/8634833667/" title="_DSC1006 by CenzoBear, on Flickr"><img src="http://farm9.staticflickr.com/8379/8634833667_44e06b997c_z.jpg" width="640" height="425" alt="_DSC1006"></a>
    <a href="http://www.flickr.com/photos/reyzo14/8637220743/" title="_DSC0983 by CenzoBear, on Flickr"><img src="http://farm9.staticflickr.com/8121/8637220743_51d8c73c13_z.jpg" width="425" height="640" alt="_DSC0983"></a>
    Now onto the performance aspect of it:
    The first thing I noticed, before I even rode them, was how snappy, and easy, the servo wave mechanism makes them. They had a definite point of engagement and the lever action from then on was very stiff, something which I like quite a bit. The test rig is a budget XC racer I'm currently building up. Rockhopper 29er:
    <a href="http://www.flickr.com/photos/reyzo14/8634839481/" title="_DSC1000 by CenzoBear, on Flickr"><img src="http://farm9.staticflickr.com/8248/8634839481_a5cc330f4b_z.jpg" width="640" height="425" alt="_DSC1000"></a>
    Then came the break in ride... which kinda sucked. Power right of the bat was whimpy and honestly quite anticlimactic. BUT once the pads finally bed in, wow! These things bite like monsters when compared to say, elixir 1's, or Tektros, or Hayes dyno comps. Two fingers with light action is all you need to lock up the tires. On the trail they're very confidence inspiring. The SLX derived master cylinder had excellent modulation(for $57) and the reach adjustments are a nice touch. I never bother to write these kinds of things because, quite frankly they take a ton of effort and motivation which I often lack, but damn these were good enough to write about! They're not the lightest by a long shot, and they're definitely not the most powerful or have the best modulation. but they perform well out of their price bracket, and make an excellent budget brake. Or at least good enough to write about! haha Does anybody else have a set of these? I'm wondering how they'll be long term, or in a race situation...
    Reputation: DavidFr's Avatar
    Apr 2013
    nice
    Dave's not here.
    Reputation: MiWolverine's Avatar
    I have the older M595s and absolutely love them. I still use the organic pads. I paired them with Avid HS1 rotors and that combo rocks.
    When I first got them, I obviously had to shorten the hoses so I figured that I would go with a different brake fluid. I stopped by a local NAPA and bought some Pentosin CHF 7.1 and have been using it ever since. There are several Shimano users on here who recommend that fluid.
    I have looked at the higher end brakes from Shimano, but have no reason to "upgrade" because these brakes work like a champ. Best brake for the buck if you ask me.
    I am the world champion of bad luck, but I tell you what, I'm undefeated!
    Oct 2012
    Quote Originally Posted by Laser4G63 View Post
    I've got some hope floaters on order to replace the stock and ridiculously bendable tektro steel, I've heard great things about them so I have high hopes. (But hey, a rotor is a rotor, right?)
    As for the fluid, the CHF doesn't foul any of the seals or anything? And what exactly was its biggest improvement over the mineral oil? I wouldn't mind giving it a try...
    2013 Rockhopper 29- The hot rod fun bike
    2013 Stumpy HT Comp 29- The racin' machine
    Dave's not here.
    Quote Originally Posted by Cenzobear View Post
    I've been using the Pentosin for almost a couple of years and haven't had a single issue. No leaks, sticky pistons, levers anything. I cannot say what differences there are exactly, but when I fiddled with the brakes before shortening the lines, the levers seemed to snap back a little quicker with the CHF. Also, it appears to work much better than the Shimano fluid in cold weather.
    One other reason why I bought the Pentosin, other than the recommendations, is because no one around me had the Shimano oil in stock. Plus, it was cheaper overall.
    I understand the CHF 7.1 is now discontinued and has been replaced with CHF 202. I have no experience with the 202, so I can't say how that is in Shimano brakes. You can still find the 7.1, but looks to cost more than what I paid.
    Even after a couple of years, I haven't used much of the fluid, so it will last a very long time.
    Oct 2012
    The pentosin is probably less compressible than the mineral oil(which is a pretty damn good advantage) and as for the cold weather, I would seriously consider it because my last set used to freeze up constantly in the winter. But granted, they were tektro... I'll have to see how these hold up next winter. I wonder what it's boiling point is in comparison to mineral oil.. I may have to do some research!
    Reputation: Mr. Lynch's Avatar
    Jun 2010
    I did a write up on them right after they were released. I have them on my 29er and I LOVE them as much as the XT brakes on my full squish 26.
    14 Aurum, 16 Fuse, 17 T130
    Dave's not here.
    There are also several posts on here about the Pentosin, some with good info and links to outside write-ups. When I found no Shimano oil nearby, the first thing I searched for here was a compatible oil for Shimano brakes. Most of the results were pointing to the CHF.
    Oct 2012
    I'm pretty happy to hear there's an alternative because that shimano stuff is running about $24 a liter(I think) right now. Definitely not cheap. And let's not forget how mineral oil get everywhere and NEVER Goes away unless you have copious amounts of isopropyl lying around...
    Reputation: supersedona's Avatar
    Dec 2012
    I've been running mineral based ATF trans oil in my Deore 525 discs for over 8 years now with no complaints. Always worked right, even in the dead of winter and never had a leak or bad seal.
    '93 Giant Sedona ATX custom
    '93 Giant Sedona AtX aero-edition
    '73 Schwinn Suburban
    '95 Fuji Suncrest
    I had the M596 brakes on the rear until recently when I made a totally unnecessary upgrade. The lever was surprisingly nice, the servowave action took a bit of getting used to but I really liked the lever shape and super easy bleeding. I didn't get the chance to ride anything with long & steep enough DH sections to fade the brakes or even get them past mildly toasty, but I was quite satisfied with their performance.
    The power is there and I think modulation is as good as any of Shimano's other 2 piston brakes, though not up to the level of the current Saints of Zees. There's a bit of a wonky spot in the Servowave action in all of Shimano's 2 piston brakes which makes feathering the brakes a bit difficult at times, but I'm pretty spoiled by the old 4 pot XTs so my standards are higher than most. One other minor issue I had was performance in freezing temperatures, when it got below -10C or so, the pistons were a bit slow to retract so that doing quick let-offs or on-off-on brake applications would result in the lever pumping up and moving the engagement point outwards. If I did it enough times in a row the freestroke would disappear entirely and I'd have to completely let off the brake for a couple seconds to return things to normal. My guess the caliper pistons seals are a bit on the tight side and cold weather hardens them just enough to make the brakes slow to return.
    Other than that, no complaints, no leaks, no noise, no trouble. They just worked and in terms of power & overall performance they were a good match for my quad piston XTs. They're good brakes, period, and taking price into consideration they're ridiculously good.
    Oct 2012
    So far I'm incredibly happy with them as well, haven't had enough time to fully test them(its been raining here in Chicago for about a week straight...) but the power is awesome. I did notice the swerve wave thing you talk about though. Right before the cam engages there's a little "sticky" spot where the lever takes more effort to engage. I don't mind it though as that's before they actually bite, so it doesn't impair feathering too much..
    100.oz minimum
    Mar 2013
    I understand that these brakes don't come with the hardware or adapters to mount them. Were you able to use your existing hardware or did you have to buy adapters & bolts?
    -always thinking about the next ride-
    Reputation: lew242's Avatar
    I've got Deore M596, SLX 666 and XT 785 all on different bikes. 596 is a no-brainer BB7 killer, but 666 is one finger endo heaven with mad modulation especially good on a 180 rotor. XT isn't really much better than SLX. Finned pads and ice-tec rotors are a bit gimmicy though unless you are doing a trail with over a 600 meter vertical drop.
    Axe
    Axe is online now
    Custom User Title
    Reputation: Axe's Avatar
    596 are very, very good. No more BB7 on budget builds.
    Dave's not here.
    Not sure what the difference is between the levers for 595 and 596 brakes, but I get 1 finger braking with my 595s. Personally speaking, I really see no advantage of upgrading to the higher series Shimano offerings. I thought about it in the past, but since these brakes are so good for me, there's really no point.
    One thing I did do when I bought mine was that I changed the cotter pin that holds the pads out to the bolt used on the XTs. All you need to do is tap one side of the caliper (forget what size tap).
    Ninja Master Powers
    Reputation: DWill's Avatar
    Aug 2010
    Quote Originally Posted by MiWolverine View Post
    This exactly what I want to with the SLX brakes I just put on my so s bike. Finding the right size tap shouldn't be difficult, finding the bolt however is a different story.
    I bought my On-One Inbred 29er SS from a mate who built her up with Formula RX's. After 100km with the Formulas, I sold them and bought M596's. Couldn't be happier!
    They have all the power, modulation and reliability one could wish for. I've had dry and dusty rides, wet and very muddy ones and not a single issue. I'm still on the same resin pads that they came with and after over 2000km, they still have at least 50% life left in em.
    Love these brakes and would find it very difficult to justify buying anything more expensive.
    Gimme some!!!
    Gettin mine soon.
    BB-sev's are till good tho...if you prefer mechs...
    roccowt.
    rocnbikemeld
    I found my M666 calipers are already tapped, they come with the cotter pin but a Shimano or even Hayes Stroker Ryde retaining pin fits.
    Dave's not here.
    Quote Originally Posted by divernick View Post
    Same here. I have around 2000 miles on the resin pads and absolutely love them. I tried semi-metallic and when they got even slightly wet, they would howl really bad. I immediately switched back to the resin.
    Reputation: toot334455's Avatar
    Apr 2013
    I have elixer 3's that need to be bled
    Can I use regular auto dot 5.1 ? or chf 7.1?
    Axe
    Axe is online now
    Custom User Title
    Quote Originally Posted by toot334455 View Post
    DOT 5.1, like Motul's. Other one is mineral oil based, not good for Avid.
    Enthusiast
    Reputation: KK89's Avatar
    May 2013
    I've got exactly the same brakes front and rear. Their my first hydros, and I like them. One finger breaking is very nice feature to have.
    They replaced the stock Promax mechanical brakes. (wich were absolute s***)
    and they cost me 80 + delivery.
    Oct 2012
    UPDATE:
    My rear brake has started leaking somewhere at the master cylinder... The lever is soft, they're starting to squeal.... I'm officially unimpressed.
    Not to mention my multiple attempts to contact Chain Reaction Cycles have been simply unanswered....
    Anybody have any ideas on how I can get them warrantied?
    100.oz minimum
    Mar 2013
    I took off my avid bb7's & put these Deores on. They have worked great so far. If they develope leaks like the op's, i will put my bb7's back on & never look back.
    Axe
    Axe is online now
    Custom User Title
    UPDATE:
    Did you try bleeding? Or do you see oil coming out?
    Mine are solid so far.
    UPDATE:
    These things are so simple, see if you can fix yourself.
    Can you see any oil leaking from the master cylinder? Chances are good that the lever is getting a bit soft due to pad wear. Mine were getting squishy and I bled them and noticed no change in lever feel. I changed the pads and voila! The squeak probably comes from contaminated pads or a dirty, oily rotor.
    Take off the wheel and clean the rotor with disc brake cleaner or isopropyl alcohol (what rotors do you have?)
    Change the pads for fresh ones.
    Report back.
    Oct 2012
    Report back.
    Oh, trust me, I'm WAY past this point. I've rebuilt the master cylinder twice already. Bled them a few times as well. Lever is great for a few days then softes up. Pads have less than 500 miles on them so it's not wear. It's definitely the diaphragm that's leaking oil. However, shimano doesn't sell replacement seal kits...
    Oki doki, sorry to hear of your struggles!
    I guess there'll always be a lemon......
    Oct 2012
    I hate to think its a lemon, because these things were awesome, and even the front is still amazing. But that damn seal!!!
    I'm gonna give shimano a call today, hopefully they'll help me out. I'll report back!
  1. Shimano Alivio vs. SLX vs. Deore XT
    By howetechnical in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-05-2014, 02:04 AM
  2. Shimano Deore XT 760
    By beammescotty in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-27-2013, 10:04 AM
  3. Shimano Deore shifters
    By Kona0197 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-09-2012, 08:06 PM
  4. replacing shimano lx deore
    By eyalriemer in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-29-2011, 04:07 AM
  5. SRAM X7 vs Shimano Deore / LX
    By zach.scofield in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-06-2011, 01:45 PM
