Results 1 to 3 of 3
    May 2013
    Shimano Deore Disc Brakes
    Can anyone recommend a good sintered metal disc brake bad for Shimano Deore M596 brakes? Are these brake compatible with sintered metal or do they get too hot? This is for my wife's bike so she will be braking a lot. Should I stay with resin pads?? They seem to wear out so quick.
    Oct 2011
    Hmm, which rotors is she using? Some rotors are not compatible with metallic pads (It should say resin pad only or something like that on the rotors). The brakes themselves are very much compatible with metallic pads but like I said first check the rotors for compatibility.
    You want Shimano M06 Metallic pads. They may be in packages labeled for XTR. They are the same shape as the A01S Resin pads.
    The cheap Shimano rotors say Resin pads only so if yours says that, maybe just keep buying resin pads until this rotor wears out...the resin pads should be cheaper.
  1. jagwire disc brake pads for shimano deore $2.93 shipped at rei.
    By texas in forum Where are the Best Deals?
    Last Post: 01-07-2013, 10:27 AM
  2. Jagwire Disc Brake Pads for Shimano Deore Brakes
    By Restricted in forum Where are the Best Deals?
    Last Post: 05-16-2012, 06:54 PM
  3. Replies: 5
    Last Post: 02-09-2012, 04:09 PM
  4. Weight of 2009 M-486 Deore Disc Brakes?
    By livinlite in forum Weight Weenies
    Last Post: 04-29-2011, 10:33 PM
  5. Shimano Deore XT brakes - leaking caliper seals
    By johna7770 in forum Brake Time
    Last Post: 03-09-2011, 08:26 PM
