Results 1 to 47 of 47
    Aug 2010
    Shimano Deore 4 Piston Brakes
    Ibis is listing Deore 4 piston brakes on their Ripmo GX build. Any idea when these will be available for retail?
    Jun 2017
    sure they aren't just failing to list them properly as 'deore XT 4 piston'? I'd be pretty pissed to get Deore level anything on a $5100 bike.
    Jun 2017
    And as far as 4 piston Deore XT (m8020):
    https://www.jensonusa.com/Shimano-XT...020-Disc-Brake
    Been running them myself for a bit now and love the shit out of them =)
    B A N N E D
    There is a new Deore 4 piston brake set, BR-MT520 + BL-MT501
    https://www.bike24.com/p2271033.html
    http://off.road.cc/content/news/shim...520-brake-2702
    Quote Originally Posted by DirtDogVT View Post
    Already available, a bit under $100 a set.
    https://blueskycycling.com/products/...501-disc-brake
    BOOM goes the dynamite!
    Reputation: noapathy's Avatar
    Quote Originally Posted by aerius View Post
    That's ummm...$100 per side.
    Coffee Drinker
    Reputation: Taildragger's Avatar
    Mar 2005
    Reputation: Sage of the Sage's Avatar
    Salsa Timberjack SS
    -Gears give me headaches
    My bad - caliper shape fooled me. Still, at $180 for a pair Zee isn't much more. Wonder what price they'll be when they're more widely available? I only see them at bluesky...wonder if that's really in stock?
    Looks like they use the BH90 hose, so most of the recent Shimano levers would be compatible but the hose connects with what looks like the Deore style setup at the caliper. Interesting possibilities.
    Jul 2017
    I've been looking for a set of ZEE brakes but can't find them for much less then M8020s which look like ZEEs with toolless adjustable reach. Anyone know a good source at a good price $240 +-?
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    Quote Originally Posted by scycllerist View Post
    Check here: https://www.bike-discount.de/en/buy/...ry_country=191
    Jul 2017
    Quote Originally Posted by Aglo View Post
    I was hopeing for a US distrubutor.
    Thanks!!
    damned rocks...
    Dec 2014
    Thanks!!
    I thought so, just wanted to give you an option.
    Jul 2017
    I guess it looks like Shimano is going for the BR-MT520 + BL-MT501 and the M8020 brake sets for 4 piston implementations. That's probably smart business and a decent product tier.
    Jul 2017
    Jensen is getting more ZEEs in this week.
    Reputation: motard5's Avatar
    I think this is the MT-501 that are coming spec'd on new 2019 Stumpjumpers, but Shimano's numbering is always confusing, especially for different markets.
    Per this article - https://www.facebook.com/notes/bird-...2367234948828/
    Deconstruction of the name helps allude to this new super-brakeís heritage. Its a 500 series product, which makes it just a bit below Deore (6-series) but actually not really as 5 & 6 series components are generally Deore level just with different slants on the OE vs aftermarket target for the product, and the BR-M520 tells us in Shimanoís new 4 pot parlance that this is a 4 piston caliper. In essence, its a non-series (ĎShimanoí branded rather than ĎDeoreí) Deore lever with a new 4 piston caliper at the other end.
    Its target is the e-Bike market, hence, I guess, the use of a non-series moniker. It means that this brake fits nicely with Alfine, Steps, Deore... whichever Shimano brand you want to chose its going to work, but you can bet your life on it appearing all over everyoneís mid range enduro and trail bikes in 2019.
    Sounds like Shimano is attempting to rebrand their lower spec brakes generically, almost private label-esque for the manufacturers. Regardless, seems like they are a proper brake, despite being a budget category.
    Jun 2017
    Quote Originally Posted by motard5 View Post
    Where are these '19 stumpys with 4 pot shimano brakes? Every model I see is either SLX (comp carbon/alloy), or Sram Guides (just about all of the rest.) Didn't check the s-works or mega-overpriced variants, but I would definitely not anticipate finding Deore on those either.
    Edit: found 501's on the ST comp alloy model. Website pics are pretty clearly 2-pot brake calipers though.
    https://www.specialized.com/us/en/me...=239758-159205
    Quote Originally Posted by Thoreau View Post
    So are MT-501's just Deore BR-M6000 brakes with a different nomenclature?
    Rollin 29s
    Reputation: isleblue65's Avatar
    Bringing this back to life. I'm having my LBS swap out a seat post before I pick up my new Ripmo (GX build), and I am a bit surprised that it is spec'd with Deore (not XT) 4-piston brakes. Ibis did this to shave costs on non Shimano builds because they aren't getting the groupo discount. Brakes are the only Shimano part on the bike.
    Have people had the variable bite problems with the Deore 4-pistons? I could have the shop swap brakes before I pick up the bike, and I would get the dealer cost back toward the new brake purchase, and 10% off new brakes which they offer when you buy a bike.
    Deore has stainless rather than ceramic pistons of the XT, and the reach adjustment requires a tool vs on the fly with a knob on XT. I think once I set the reach, I wouldn't mess with it again, but the ceramic pistons will transfer less heat into the fluid.
    Deore 4-pistons may be fine brakes, and it may not be worth the swap. Still can't help but to think it's a mismatch lower level component based on the rest of the bike.
    Whoever invented the bicycle deserves the thanks of humanity.
    - Lord Charles Beresford
    B A N N E D
    Quote Originally Posted by isleblue65 View Post
    They don't have stainless steel pistons, they have ceramic pistons like the SLX/XT/XTR.
    BR-MT520 Specs: http://productinfo.shimano.com/#/spe...0disc%20brake)
    Rollin 29s
    Quote Originally Posted by cobba View Post
    BR-MT520 Specs: 2018-2019 SHIMANO Product Information Web
    That spec sheet shows the Deore has resin pistons, not ceramic.
    B A N N E D
    The Deore brake with resin pistons that you're looking at only has 2 pistons.
    The BR-MT520 is the 4 piston 'Deore' which they list as having ceramic pistons.
    Shimano don't list this 4 piston brake as 'Deore' but that's what it's being called.
    * Shimano says they do have ceramic pistons, the second article says they don't have ceramic pistons but the pistons look to be the same as the ones in the photo of the XT 8020 brake that's next to it.
    Rollin 29s
    Thanks for clarifying. theres not much information about these yet, and it seems that most of the variable bite position issues are happening on XT and Saint models.
    Weight differences between these and XT/ XTR are pretty insignificant, and the few online reviewers seemed to like them - some even better than XT.
    I donít really have anything to justify swapping these for a Ďhigherí Shimano designation or another brand, so Iíll probably ride them. As they are priced to be mass market 4-piston brakes, and even targeting the E-Bike segment, Shimano is going to want them to be solid.
    Jul 2018
    I bought a HD4 a couple months ago right as Ibis started spec'ing the GX builds with the BR-MT520 brakes. I was planning on upgrading to XT but my LBS talked me into staying with the new 4 pistons. I was coming off a bike with Guide R brakes which were mediocre at best so braking performance on my HD4 was a priority. After a few months of riding, I can honestly say that I am happy with their performance. Much better than my Guides.
    Rollin 29s
    Quote Originally Posted by rynomx785 View Post
    That's good to hear. have you had to re-adjust the reach once initially setup? Not having the XT on the fly reach adjustment knob seems like a potential pain. On my Elixir CRs, I've used the manual reach adjustment knob dozens of times over the years on the trail when I've wanted more or less reach or to change engagement position to reduce fatigue on long descents. Having to pull out a multi-tool, or carry a small torx wrench to do this sounds like a hassle. Maybe not worth the cost to upgrade or buy something else, but it's a consideration.
    Jul 2018
    That is my only real complain with them is I wish I could adjust the bite point like you can on the XTs. The way the shop had it set up, the levers were hitting my middle fingers right around the same time they would start to bite. I ended moving them in on the bars further and it has been fine. If you use 2 fingers to brake it may be an issue. I have done some pretty long high speed descents and I have never felt like I needed to adjust the bite point. I have fairly large hands so the reach has never been an issue for me.
    Rollin 29s
    Do they only have a bite point adjustment? You say you physically moved the brake levers further in on the bars rather than adjusting the reach further out, which sounds like there is no reach adjustment. That would be a definite deal breaker for me. When I test rode the Ripmo yesterday, the levers came way too far in (pressing into my fingers on hard braking - and I use 2 fingers). I didnít think much of it because I saw the adjustment screw, which I thought was reach. The Elixirs have reach and bite. You have nearly infinite adjustment.
    Jul 2018
    No they only have reach adjustment. They need the bite point adjustment to make them bite prior to the levers hitting my fingers. Reach only adjusts how close the lever sits to to the bite point which has no effect on where the lever is in when it starts to bite.
    Jul 2018
    The calipers are nearly identical to 4 piston XT calipers minus the cooling fins and ceramic pistons. If you want the tooless adjustments, just get XT levers.
    Rollin 29s
    I called my shop about the BR-MT520 and told them about my concern about lever positioning, reach and bite.
    The mechanic I talked to said that the lever positioning could be tweaked via a combination of making sure they are completely bled and adjustment of the screw to make the bite happen further out on the lever position. He said these Deore levers had identical adjustability to the XT, and the only difference is the requirement to use a tool rather than the manual knob.
    Iím not sure if this is correct or not.
    Jul 2018
    Hmmmm Maybe I will have mine bled again and see if it helps. I need to call my shop this afternoon so I will see what they say about bite point adjustment outside of just bleeding.
    Rollin 29s
    So far so good with these brakes. The shop adjusted the levers and bite point out about 1.5 - 1.75Ē from the bars where I wanted them, and aside from squealing when the pads heat up on the two cold morning rides Iíve done, they modulate well and have about double the stopping power that my Avid Elixir CRs do.
    Iím hoping the squeal is break in, and will go away soon.
    Jul 2018
    Nice! I am pretty sure I need to have mine bled to get them to bit sooner.
    B A N N E D
    The calipers are nearly identical to 4 piston XT calipers minus the......ceramic pistons.
    Are you sure about that?
    Rollin 29s
    Those are ceramic
    B A N N E D
    Those are ceramic
    Just like the XT's
    May 2005
    Iím tired of the variable bite point on my 2 pot XTís: do the 4 pot XT and Deore have this issue too?
    The difference in price I can get them is no too big, so Iíd rather go with XT as they look nicer, but only if they donít have the pumping issues.
    Iím 75 kg so donít need loads of stopping power, but Iím looking for good modulation.
    Rollin 29s
    Quote Originally Posted by spaniardclimber View Post
    After this weekend at Downieville as my first test of the Deore, They performed flawlessly. Great modulation and bite was consistent.
    Jul 2018
    Nope! lol
    Rollin 29s
    Those rotors sure vibrate and squeal when hot though!
    They hit a resonance sometime where they physically shake the front end, and you have to release and re engage the brakes to stop it. They have had several hundred miles to break in so far and it happens every ride when braking a lot.
    Jul 2018
    I haven't experienced anything like that.
    May 2005
    Did you use brand new discs?
    Reputation: mr_manny's Avatar
    May 2016
    Didn't realize they existed...already have Zees on the way
    Rollin 29s
    Yes, brand new everything on new Ripmo.
    since 4/10/2009
    Reputation: Harold's Avatar
    Resin or metallic pads? Everything you're describing to me sounds like resin pads. I prefer metallic pads, as they tend to get quieter as they heat up, IME (they will howl a storm if they get wet and are cold, but as they warm up and the water bakes off, they quiet down).
    Rollin 29s
    Quote Originally Posted by Harold View Post
    Iíll check when I get home. Unfortunately thatís the one item that the Ibis spec sheet doesnít clarify. This morning it was foggy and cold, and the pads didnít make any noise. Iíll definitely install metallic pads if it is resin pads now. Iíve also swapped my rotors in the past with Alligator Wind Cutters, and had great luck with those. Much better than Shimano and Avids Iíve used.
    May 2016
    Looks like they offer both metallic and resin pads for the new MT520:
    Attached Thumbnails Attached Thumbnails Shimano Deore 4 Piston Brakes-new4deore.png
  1. MTB shimano deore derrailour dont fit my new shimano deore crankset????
    By Lennyz in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-11-2013, 12:36 PM
  2. Tech: Mays mag.g2 caliper piston leak, piston removal?
    By Jake_HT in forum Downhill - Freeride
    Last Post: 04-29-2013, 06:31 AM
  3. Saint/Zee 4 piston caliper piston sizing
    By MichaelB in forum Brake Time
    Last Post: 03-19-2013, 08:29 PM
  4. Replies: 1
    Last Post: 01-02-2013, 03:15 PM
  5. Shimano Deore 555s - One piston or two?
    By alexandros in forum Brake Time
    Last Post: 12-07-2006, 09:54 AM
Members who have read this thread: 318
