    Han
    Han is offline
    Aug 2013
    Shimano center lock brakes and Easton EA 70 XC 6 bolt wheels?
    I've searched and found lots of info on adapters to go from Shimano center lock rotors to 6 bolt but what about the opposite? Is there an adaptor to make 6 bolt wheels work with Shimano center lock mechanical 160 mm brakes/rotors? The wheels are new to the bike and I'm already using a 15 mm to 5 mm axle to fit my dropouts.
    Http://www.motohobos.wordpress.com
    Mar 2013
    Just buy the six bolt Shimano rotors. I don't think it is possible to get a centre lock rotor onto a six bolt hub for spacing reasons.
    B A N N E D
    You can't put centerlock rotors on 6 bolt hubs and there is no adapter that will allow you do it.
    If you buy 6 bolt hubs you will also need to buy 6 bolt rotors.
    Han
    Han is offline
    Aug 2013
    Makes sense, thanks for the info! Anybody wanna swap centerlocks for 6 bolts?
  1. center lock vs. 6-bolt recommendation
    By wyo_biker in forum Brake Time
    Last Post: 06-12-2016, 01:44 PM
  2. What's the best center lock to 6 bolt adapter
    By glader60 in forum Wheels and Tires
    Last Post: 08-10-2013, 09:01 AM
  3. 6-Bolt or Center Lock
    By DirtyHank in forum Brake Time
    Last Post: 05-14-2013, 08:56 AM
  4. Looking for a 6 bolt to center lock solution
    By eggdog in forum Brake Time
    Last Post: 01-10-2013, 06:06 AM
  5. center lock or six bolt?
    By agave802003 in forum Brake Time
    Last Post: 07-15-2012, 07:08 PM
