    Reputation: in the trees's Avatar
    Mar 2005
    Shimano Calipers with Cotter Pins
    Are these calipers (SLX, Zee, etc) threaded for regular pad fixing pins as well?
    May 2012
    Yes. I replaced the cotter pins on my SLX calipers with threaded pad retention pins and clips. Got them here. Went with the ones for $4, as they have the hex head, rather than the slotted.
    The Zee is threaded for a pad retention bolt, I stole one from a spare set of M755 calipers I had and put it in there. The M596 Deore on the other hand isn't threaded for a bolt, you'll have to run a tap through the hole to cut some threads into it.
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    SLX definitely is.
    Axle Standards Explained
    Founder at North Atlantic Dirt, riding & writing about trails in the northeast.
  1. Shimano A530 pedals with traction pins
    By ScottParsley in forum All Mountain
    Last Post: 01-23-2013, 03:29 PM
  2. Chain pins for shimano.
    By aBicycle in forum General Discussion
    Last Post: 01-05-2013, 10:10 PM
  3. Magura and Shimano adapters for Shimano calipers
    By crazylax42 in forum Brake Time
    Last Post: 05-10-2012, 08:48 PM
  4. Correct Shimano chain pins for XT chains?
    By duffin in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-07-2012, 10:48 PM
  5. shimano DX pedal pins?
    By Goliath_2 in forum Downhill - Freeride
    Last Post: 07-22-2011, 10:36 PM
