Results 1 to 6 of 6
    Reputation: Slurry's Avatar
    Dec 2008
    Shimano Brakes & Degassing Mineral Oil
    Is there any reason why Shimano never makes any mention of degassing mineral oil prior to using it in a brake bleed? I've been bleeding brakes for a while now, and I found it interesting that Avid makes a big deal out of degassing DOT fluid before introducing it into the brake system, while Shimano doesn't even mention it.
    I recently took a red hose-clamp off one off an old Avid bleed kit and installed it on the syringe hose that i use for bleeding Shimano brakes, and thus I can degas the mineral oil in a similar fashion.
    I can't tell how big of a difference it makes, but there is definitely air dissolved in there, so I just found it odd that Shimano doesn't have it as a step in their brake bleeding procedure.
    How much does it weigh?
    Reputation: Borgschulze's Avatar
    Nov 2007
    I believe Mineral Oil doesn't hold air like DOT fluid does.
    The air in DOT fluid can also have moisture in it, which reduces the boiling point.
    Sheffield,South Yorkshire
    Reputation: ibbo's Avatar
    Because Avid seem to complicate a very uncomplicated procedure Nobody degasses car/motorcycle fluid which is exactly the same
    Dec 2008
    Quote Originally Posted by ibbo View Post
    Interesting, I was not aware that degassing isn't performed on other hydraulic brake systems. Like I mentioned, I can't really tell if degassing has made a difference in performance/fade resistance.
    I have both Hope and Formula and degassing isn't mentioned on either. Formula also use syringes (exactly the same as Avid ) but you just bleed them and don't faff around.
    all hydraulic fluids, oil included, benefit from degassing. ignorance is not a defense. google is your friend.
