Results 1 to 3 of 3
    May 2013
    Shimano BR-M395 or Shimano BR-M445
    I am in the process of choosing a moderately priced bike for my friend and I have a question about low-range Shimano hydraulic disc brakes.
    I have Shimano BR-M445 on my Cube Analog Disc 2012. I went to the Cube site and saw that the 2013 model range is equipped with Shimano BR-M395. A lot of 2013 bikes from other manufacturers are equipped with Shimano BR-M395 as well.
    On the internet, some people make an assumption that Shimano BR-M395 are the new version of Shimano BR-M445, just named awkwardly. It is believable, but I am not so sure about this. Can someone shed some light on this?
    Reputation: Aresab's Avatar
    They use the same pads and are similar but slightly cheaper looking, I notice the bleed screw on the M395's is different. Not sure if it's as easy to bleed, it looks to be a screw rather than a nipple. I could not find bleeding instructions in a quick search of Shimano. They are both low end, but I'm sure will work fine. If I recall M3XX are Acera and M4xxx are Alivio, but trickle down technology makes them very similar.
    May 2013
    Okay, thanks for clarifying this!
  1. Broken Shimano BR-M445?
    By oregoncurtis in forum Brake Time
    Last Post: 05-28-2017, 11:31 AM
  2. Shimano M395 better than Avid Elixir 1?
    By Trek13 in forum Brake Time
    Last Post: 06-26-2013, 12:28 PM
  3. Shimano BR M445 -> M585
    By boardreader in forum Brake Time
    Last Post: 02-11-2013, 01:01 PM
  4. Shimano BR M445
    By jb2011 in forum Brake Time
    Last Post: 06-15-2011, 08:22 AM
  5. Shimano BR-M445
    By wisdom200632 in forum Brake Time
    Last Post: 04-27-2011, 04:09 PM
