Results 1 to 3 of 3
    I Like Bicycles
    Reputation: Thimk's Avatar
    Shimano adapters with Hope/Magura?
    Will Shimano adapters fit with other brand disc calipers? It seems as though they will, but I would like to just double check before spending $300.
    Reputation: oldskoolbiker's Avatar
    Jun 2005
    Yes they should fit, just make sure you're using the exact same size rotor as the adapter is made for. e.g., don't use 185mm rotors with a 180mm adapter. or 200mm rotors with 203mm adapter.
    I Like Bicycles
    Keww... For sure, 203mm adapters with 203mm rotors.
