Results 1 to 2 of 2
    Reputation: Pollution Warrior's Avatar
    Shimano 203mm adapter on BB7?
    I'm thinking about putting a 203mm rotor on the front. I have a BB7 on the front now with a 185mm rotor.
    I have a Shimano 203mm adapter already that I acquired somehow but never used. Would I be able to use it with the BB7 and an Aligator 203mm rotor? In other words, are Avid and Shimano 203mm adapters interchangeable?
    B A N N E D
    You can use the Shimano adapter, you'll need to use the CPS washers as you do with the Avid adapter.
