Results 1 to 3 of 3
    Setting up new Magura's, need help
    I am helping my friend build up a new blur with 2004 louise discs. I have bleed the 03 brakes using the method on the Magura Cult site and all is usually good. Here's the problem I am having with these new ones, I can ALWAYS get a ton of air bubbles to come out when I reverse bleed via the lever. I have run the fluid through 20 times and there is still loads of air coming out. I have never had to do this more than 4 or 5 times in the past the get a near perfect bleed.
    I figured there had to be a leak in the line filled them up as best I could and gave it a shot. The lever would engage very solid about 2mm from the bar, not suitable for riding, but I could build up lots of pressure. Squeezed em real good, waited a bit, squeezed them for a while longer and found no noticeable leaks. Any ideas on what's going on? Maybe the fittings on my bleed kit are going bad?
    A wheelist
    Reputation: Mike T.'s Avatar
    Quote Originally Posted by AKBiker
    Remove the o-ring from the bleed fitting and try again.
    Mike T. (mcm # 717)
    Mike T's home wheelbuilding site - dedicated to providing Newby wheelbuilders with information and motivation.
    I tried it w/o the o-ring and with another bleed fitting that I found lying around hadn't been used yet and had the same result.
  1. ETSX and Talas, which travel setting?
    By Portti in forum Canadian Bikes
    Last Post: 11-28-2004, 04:26 PM
  2. Racer X ride in 3.5" SB setting ?
    By DH_WP in forum Titus
    Last Post: 08-18-2004, 01:44 PM
  3. Tracer with Vanilla 125, best linkage setting?
    By Count Zero in forum Intense
    Last Post: 08-16-2004, 11:57 AM
  4. NRS SID rear shock rebound setting?
    By ekin in forum Giant
    Last Post: 06-09-2004, 08:10 PM
  5. Minute 3 and 100mm setting
    By noosa2 in forum Shocks and Suspension
    Last Post: 05-26-2004, 02:01 PM
