Results 1 to 10 of 10
    Reputation: MMcG's Avatar
    Jul 2003
    In search of a source for a Magura Louise Post Mount Adaptor
    I just picked up a Mars Elite fork to pair up with an old 2001 Schwinn Rocket 88 that my girlfriend rides primarily but that also fits me. The bike originally came with a Zoke from the original owner and that fork went on my son's bike.
    Brakes are 2001 Magura Louise with 6" rotors and IS mount calipers.
    I need to find and buy a post mount adaptor in order to run the Magura disc brake up front. Can anyone help me out with a source to purchase one?
    Will it be a major PITA to find one?
    Any help would be hugely appreciated.
    Mark
    Former Bike Wrench
    Easy to find, but you'll need to go 180mm on the front rotor
    a2z components
    http://www.a2zcomponents.com/ada.htm
    Magura part number 0721643
    http://www.magurausa.com/store/shopp...+Caliper+Parts
    Jul 2003
    So I've also gotta buy a larger rotor? That sorta sucks.
    Former Bike Wrench
    But...
    Quote Originally Posted by MMcG
    Cheaper than a caliper
    Jul 2003
    yeah but is it wise to use a 180mm rotor on an XC fork???
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    zoke doesn't endorse it (at least until the 07 32mm models), but I used a 180mm in my MX and Marathon without issues.
    Jul 2003
    hrmmmm....maybe I'll move this pair of Hydros to a different bike and get something else for this Schwinn.
    Crapola.
    Former Bike Wrench
    As I recall, the 2001 Julie is a single piston brake...I would be seriously surprised if it caused any problems with a 180mm rotor on that Mars. Post Mounts are way stronger than IS mounts and that brake doesn't generate huge amounts of power. If the rotor clears the fork leg, I don't see any problems.
    Jul 2003
    Louises not Julies though.
    Former Bike Wrench
    Woops...but still a single piston
    My bad on the confusion, but the Louise is still a single piston as I recall with an adjustable inboard pad (like most mechanicals). So I still don't think it'll be an issue on the Mars to run a 180mm rotor...as long as the rotor clears the lower leg.
