Results 1 to 7 of 7
    Reputation: hardway's Avatar
    Saint Rear Derailleurs
    I'm looking at a saint rd because I'm sick of bending hangers. I run an 8 speed rear sprocket and the Saint says it's for nine speeds. Will it work on my 8 speed?
    -> SickLines.com <-
    Reputation: mtb_biker's Avatar
    It shouldn't be a problem.
    ...idios...
    Reputation: SteveUK's Avatar
    It should work on an 8 speed system, but are you aware that the Saint and Hone rear derailleurs require a specific hub/axle (< < link)?
    Diogenes
    Meh.
    Reputation: XSL_WiLL's Avatar
    Are you aware that you posted a question about derailleurs in the brake forum?
    Yes, it will work with 8 speed if paired up with an 8 speed shifter. 8 speed and 9 speed cover the same overall range. The derailleur doesn't know how many speeds there are, it just does what the shifter tells it to.
    Thanks, sorry about the wrong forum thing. I know the chains are different sizes, so I wanted to make sure the saint would fit the 8 sp. chain.
    How would a new type of derailleur help prevent bending hangers?
    because there is no hanger with the saint, it screws right onto the axle.
