Results 1 to 3 of 3
    rider
    Jan 2005
    Saint M815 rear hub with 203mm CL rotor and Avid BB7's?
    Can I run a M-815 150mm x 12mm rear hub and Ice Tec centerlock rotor with a set of 2011 203mm BB7's? Yes, I could get the Shimano 6 bolt rotor adapter and run the regular Avid rotor, but like the Ice Tec rotor idea.
    Does anyone have any input on the Saint Ice Tec Rt81 203mm Disc Rotor as far as actually being superior in dissipating heat?
    Abandoned the 26" wheel in May '03
    Huckin' trails
    Reputation: David C's Avatar
    Quote Originally Posted by 29erchico View Post
    You could run the Shimano rotor, as long as its pretty much the same thickness and the braking zone is equal or larger to the BB7 pads, which covers all the braking zone on the 203mm G2 rotor... I might get you a measurement of the braking zone on the G2 to help you compare.
    David
    Quote Originally Posted by NicoleB28 View Post
    topless. that's what all mtb girls do. we go ride, get topless, have pillow fights in the woods, scissor, then ride home!
    Reputation: Wombat's Avatar
    I use an Alfine centrelock hub and a standard XT 203mm (non ICE Tec) with BB7s and they work well. I assume the Ice Tecs have the same dimensions,
    Tim
  1. Saint M810/M815 Rear Hub Feedback
    By Slurry in forum Downhill - Freeride
    Last Post: 08-15-2014, 04:34 PM
  2. Avid Juicy 3.5 160mm to 203mm rotor
    By XAP72 in forum Brake Time
    Last Post: 01-11-2011, 07:26 AM
  3. Shimano Saint Rear Hub M815
    By Binford in forum Shimano
    Last Post: 03-12-2010, 07:10 PM
  4. Replies: 1
    Last Post: 09-15-2006, 04:01 PM
  5. Where to get Avid 203mm Rotor?
    By eanzenberg in forum Where are the Best Deals?
    Last Post: 11-16-2005, 12:18 AM
