Results 1 to 2 of 2
    saint m800 vs 07 avid juicy 7
    which one is better?
    thank u
    it's a big problem
    ~~~~aaaAAAAAAAAAA
    which one?
    Reputation: Znarf's Avatar
    saints are super reliable, have a really consistent lever feel, good braking power and very little fading. they have perfect modulation.
    juicys are also quite grabby, they have a bit more bite, they are however not stronger in terms of braking power, its just that the first squeeze "bites" bit more.
    the juicy levers feel a bit mushier because of the dot fluid, shimanos use mineral oil, itīs a big plus in my oppinion.
    you wonīt go wrong with either brake. The speed dial (additional lever adjustment) is not necessary, there are quite a few people however who donīt want to miss it.
    Iīd go with the Saints personally, at least if they have big rotors. I have better experiences with them, compared to the Juicies iīve used. The Juicies are fine brakes as well though.
    Get what is cheaper/looks more appealing to you.
    Greetings Z.
