Results 1 to 3 of 3
    parts leftover
    Reputation: schlim's Avatar
    Saint centerlock with Marzocchi Z1?
    I just tried to mount a new Saint 203mm centerlock front rotor on a Saint hub laced to a Rhyno Lite rim. The fork is a Marzocchi Z1 Light with a 20mm through-axle.
    Here's my problem: the lock ring on the disc wedges against the fork when the axle is secured. What the heck? The wheel doesn't even turn!
    Has anyone else run into this? Do I need to ditch the centerlock brakes? Find a different fork? Grind something off? Any feedback would be helpful!
    Rocket Scientist
    Mar 2005
    I test fit my saint hub with 8" rotors on a 66rc2x and it fit fine. I'm surprised there are clearance issues. Got any pics? Did you get the lockring fully torqued down?
    parts leftover
    Good call, I got the lockring torqued down further, and that solved the problem. Whew! Thanks!
