Results 1 to 5 of 5
    ¡Manos arriba!
    Reputation: NoDunut4U's Avatar
    running with scissors!!!!!
    Avid Mechanical discs in the front, Hope DH4 Hydraulics in the rear of a 29" SingleSpeed. I had an uncle who's second cousin did this and the back of his skull got blown right off his head first time he squeezed both brake levers at the same time!!!! But I aint skeer'd.... I even play golf in the rain! HaaaaHaaaaaHaaaaa
    Reputation: 006_007's Avatar
    ¡Manos arriba!
    Quote Originally Posted by 006_007
    That would look AWESOME duct-tapes to the headtube of the bike!!!!!
    mtbr remember
    Reputation: BikeSATORI's Avatar
    Why the hydro in rear and mech in front??? I would want the dh4 in front for sure, for better feel and power.
    btw- what is so risky about doing that?? the 29er or something? You will just need some stout hubs and large rotors.
    Schralp it Heavy.
    ¡Manos arriba!
    Quote Originally Posted by BikeSATORI
    Because I had a Avid front and a Hope rear already in the Pile 'O Spare Parts.
    I could order a rear bracket fo the Avids and cut the line for the Hopes and have the right hand work the front brakes.... but that would be just too goofy! Also, it seems the shorter cable run for the mechanicals up front, and hydraulics for the long run seem to make more sense.
    I have a bad habit of clipping my brake lever on passing tree's which blows out a relief seal on the Hopes.... (replaced 4 times already) once that happes it renders the brakes useless for the duration of the ride, if I loose brakes, I'd like it to be the rear.
    It's just that it seems so odd to everybody... ( makes pefect sense to me though.)
    Surly New Disc (SS) Hubs.
    Standard 160mm rotors. I'll upgrade in a few years, when the used prices on E$ay drop on the larger set-ups.
  1. For those running 100mm or more on you surly...
    By BigSur in forum Singlespeed
    Last Post: 08-26-2004, 10:49 AM
  2. Replies: 9
    Last Post: 06-08-2004, 10:32 AM
  3. What rebound setting are you running 04 SJ
    By wayneosdias in forum Specialized
    Last Post: 04-19-2004, 11:04 AM
  4. So what fork are all the WW's running?
    By Crash_FLMB in forum Weight Weenies
    Last Post: 04-05-2004, 08:07 AM
  5. Hip to knee running injury...
    By DCepp in forum Rider Down, injuries and recovery
    Last Post: 03-22-2004, 12:17 PM
