Results 1 to 5 of 5
    Reputation: SycoCell121's Avatar
    Roundagon disc vs. G2 clean sweep
    I have a set of 160mm roundagon discs (avid bb5) and g2 rotors. I run Juicy 7 brakes. Can the roundagon disc work with the juicy 7 caliper?
    Yeah, but they suck...........................
    The G2 or G3 rotors are way better.
    You can also run Hope, Magura, Formula, 160 mm rotors too.
    Lead by my Lefty............... right down the trail, no brakes.
    Reputation: peternguyen's Avatar
    What are the improvements of the G3 rotors over the Roundagons? By design, they look like they'll dissipate heat better. Is there any improvement in modulation?
    Jul 2003
    With Avid BB brakes....
    modulation is pretty much a function of set up. The rotors make little differenc. Where the G2 and G3 rotors improve over the Roundagons is less heat build up and quicker heat disipation. Also due to better slotting they keep the caliper clear of mud a guck better. And they're a tad lighter as well. Other than that a BB7 or BB5 have the same potential for power and modulation with a Roundagon as with a G2 or G3 rotor.
    Good Dirt
    I have BB7s and went from a roundagon to a G2. Modulation was unchanged. The G2 seemed to require less effort. I couldn't get either rotor to fade after many attempts so I can't comment on fade resistance but from my own tests posted on here a long time ago the G2 seemed to run cooler. Noise was reduced with the G2 especially when wet.
    '08 Hardrock HRXC
    '09 Epic Comp
    '14 Trance SX -
