Results 1 to 10 of 10
    xc racer wannabe
    Reputation: jonwebah's Avatar
    Rotor's T25 bolts stripping
    Just bought a new disc wheelset cuz my last one is finished. So, I take a ratchet and a T25 bit to remove the discs from my old front wheel. hmm... they're on there pretty darn tight (these are the wheels and discs that came with my bike; preassembled). I have some success with a couple of the bolts, but end up stripping two of them. Extremely tight and in the end i was unable to get any of the bolts off. In addition, my bit (which is likely not of terribly high quality) began to twist. this is when i stopped.
    so: how can i get these stripped bolts off and is this normal for discs?
    Я говорю по русски. А вы?
    same thing happen to me so i took it into my LBS and they use there high quality torx wrenchand took the stripped bolt right off without any problem(didn't charge me anything ) . i say take it to your LBS or buy a better torx wrench.
    xc racer wannabe
    k thanks
    xc racer wannabe
    well i just took it to LBS and even they are cautious about their abilities to remove the disc given that 2 bolts are stripped. the other four are off, but there's no guarantee that these last two will loosen up.
    any remedies/suggestions for stripped bolts/screws??
    Reputation: lebikerboy's Avatar
    Jan 2005
    I've had the same problem in the past. I used one of the bits Sears sells to remove trashed screws and managed to get two of the three out. For the last one, I ground the torx head completely off and after removing the disk, used a pair of small vice grips to remove the last piece of bolt. Or as an alternative, try another large shop where downhiller/freeriders frequent. They're more likely to have more experience at this sort of thing.
    Quote Originally Posted by jonwebah
    xc racer wannabe
    ah good calls -- i'm now beginning to see the perks of sh!tmano's new saint splined rotor system. this 6 bolt setup needs to be improved.
    Reputation: frank n. beans's Avatar
    There is nothing wrong with the 6 bolt setup as long as they are installed correctly. They don't need much torque, and a sharp tool always helps.
    Don't believe everything that you think.
    Reputation: wayneosdias's Avatar
    take a dremel and shear the heads off, buy 6 new bolts and a quality T bit. Ive done this to a couple of wheels when I was using the soft torx wrench that came w/my avids.
    wayne
    89 Univega HT -???-
    92 Specd SJ HT M2 -stolen-
    92 Specd SJ HT M2 -sold-
    94 Specd SJ HT M2 -sold-
    97 Klien Mantra -sold-
    01 Specd enduro FSR
    02 Specd enduro FSR -sold-
    04 Specd stumpjumper FSR
    05 Specd enduro FSR Sworks
    Authority is dead!
    Reputation: Lucky13's Avatar
    Yes, we do speak Russian as well.
    Get a dremel, make a horizontal cut in the head of what's left from it so you can use a flat head screw driver to get 'em out. I usually put a little locktite on the bolt, but never make it tight; just enough for the to hold a rotor without play. Locktite does the rest.
    For the love of Oi
    Rent a house at Attitash
    Look at the time!
    Reputation: lelebebbel's Avatar
    Jan 2005
    have you tried to heaten the bolts a bit? this might help to "crack" the loctite (or whatever they used on your disc to secure the bolts). you could use a hairdryer for this.
    wanted: Cannondale Lefty w/ V-brake studs
  1. self extracing versus standard bolts?
    By mountain bike in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-09-2004, 09:09 AM
  2. bolts bolts bolts
    By gic in forum Weight Weenies
    Last Post: 08-26-2004, 11:56 AM
  3. alloy stem bolts and brake boss bolts??
    By carbnjunkie in forum Weight Weenies
    Last Post: 06-24-2004, 10:50 AM
  4. Disc wheels with titanium spokes
    By gpfbike in forum Wheels and Tires
    Last Post: 05-03-2004, 06:58 AM
  5. Replies: 14
    Last Post: 04-23-2004, 02:35 PM
