Results 1 to 5 of 5
    Reputation: phaffas's Avatar
    Rotors that suit Avid Elixir 5 ?
    Im replacing a bent avid 160mm rotor on the front. This may be a stupid question... but can i use any brand of 6 bolt 160mm rotor with Avid Elixir 5 hydraulic brakes...? Or are some brands for some reason not compatible?
    cheers
    yeah, you can use any brand 6-bolt rotor. But the Avid HS1's are pretty inexpensive (cheaper than the G2 & G3 Cleansweep rotors)....
    Reputation: joe_bloe's Avatar
    I just got some Magura rotors off Chainlove for $5 each. They're great.
    What is the difference between G2 and G3 rotors?
    Never trust a fart
    Reputation: frdfandc's Avatar
    The pad sweep area of the G3 is smaller than the G2 due to the smaller brake pad of the Elixer vs the Juicy/BB7's.
