Results 1 to 6 of 6
    Oct 2007
    Which rotors for Shimano M08 resin Pads?
    Hi, i have shimano 2006 Br-M475 mechanical disc calipers which use M08 resin pads. My rotors are not for sale anywhere and i was wondering what rotors are compatible with these pads. are shimano xt SM-RT75 compatible?any insight appreciated.
    Former Bike Wrench
    I would look at a set of Alligator Rotors...standard for Resin pads (don't get the serrated ones for resin pads)
    Cheap and they work
    Reputation: johnnyspoke's Avatar
    I learned the hard way that the xt rotor has a narrower braking track than the M08 pad. You need a st 51 or 53...something like that, I don't have my bike in front of me I found them on ebay.
    I'm looking forward to regretting this.......
    Oct 2007
    Thanks for the suggestion-looking into them now. On closer inspection my rotors are Shimano SM-RT50, but RT60 rotors are also recommended. Only found one pair of RT50's for sale, they claim to be new but the surface of the rotors apperas to be abbraised, is this normal? a link to them is here http://cgi.ebay.com.au/2-x-Shimano-1...QQcmdZViewItem
    any thoughts on this once again appreciated
    Those rotors are new, and look good. Its from how they are manufactured.
    Former Bike Wrench
    the "abbrasion" you see is surface prep, it helps the pads burn in. Auto mechanics do the same thing to freshly turned auto rotors
    as far as I can tell, they're new
