Results 1 to 3 of 3
    Rotors for Avid Mech.?
    Anyone using different rotors with Avids. I need new rotors and was thinking of going with a wave design to help with heat. Any suggestions?
    Reputation: nwmtb's Avatar
    rotor recommendation
    Quote Originally Posted by RM27
    I assume your running fairly current mechanicals, because i think the 2001 Avid mechanicals were using a 165mm rotor...
    Anyway, i've had really good luck with the Galfer line of brake components, and i've even used the wavy galfer rotor's mixed with Avid mechanical calipers...with great success.
    later, Chad
    chad@redbarnbicycles.com
    On MTBR hiatus :(
    So far, so good...
    Just about anything you find in the correct diameter should work. I've been running 2.0mm thick Rohloff rotors on three bikes, and a set of custom Hope wavy on another.
  1. Replies: 2
    Last Post: 03-01-2004, 06:01 PM
  2. Changing pads & rotors
    By frank daleview in forum Brake Time
    Last Post: 02-17-2004, 06:16 AM
  3. Help w/ replacement rotors for Avid Mechs
    By ThornPatch in forum Brake Time
    Last Post: 02-03-2004, 02:23 PM
  4. Replies: 8
    Last Post: 01-20-2004, 03:20 PM
  5. dumping avid vee's for mech!! more!
    By KamikazeBikr in forum Brake Time
    Last Post: 01-20-2004, 12:35 PM
