Results 1 to 7 of 7
    Yes, that's fonetic
    Reputation: whoda*huck's Avatar
    Feb 2005
    Rotor warp under heavy braking
    It happened again yesterday. There's a long steep paved road at the end of a long local DH run (many thousand feet). Coming to a stop at the bottom takes quite a bit of braking and near the bottom my front rotor starts to warp and get wobbly...I'm talking as much as a quarter inch of deflection each way...then it goes back straight after a few moments of cooling when I stop. I'm running Formula K24's with a 203 Alligator front rotor. Is this normal or is the Alligator just a wimpy rotor?
    meh....
    Reputation: Monte's Avatar
    Alligator rotors are probably a little wimpy for that much heat since they are lighter than others. lighter means less material, so they'll get hotter. if it's a problem, get a heavier rotor. it'll probably still warp a bit, but probably not as much.
    Never trust a fart
    Reputation: frdfandc's Avatar
    One thing to add, how much rear brake are you using to help slow you down?
    Yes, that's fonetic
    Feb 2005
    Quote Originally Posted by frdfandc
    Just enough to not break traction. (I'm no noob.)
    Binned
    Nov 2008
    Dump the 'Gators and invest in and install some heavier workhorse type rotors.
    Never trust a fart
    Ok, just asking. Might have to try a different rotor. Something with just a little bit more material.
    Yes, that's fonetic
    Feb 2005
    Quote Originally Posted by ambassadorhawg
    That's the plan. What's a few milligrams when you're already over 40lbs?
