Results 1 to 5 of 5
    Binned
    Nov 2008
    Rotor Thickness Request
    Looking for lighter weight rotors to shave some grams off my goat.
    What is the thickness of the Aliigator Windcutter, Ashima Airotor AND Formula R1 rotor??
    I am using Magura Marta SL brakes so I'd like to make sure that the rotor thickness is compatible with these brakes.
    Also looking for any other suggestions to replace the Magura Wavy SL rotors to save weight.
    Thanks,
    'hawg
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    I have both sets of those rotors ... here is the Windcutter thickness, I will have to take a pic of the Ashima rotor later
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    At 1.74mm pictured above is very close to Magura's rotor wear limit of 1.70mm. You need rotors at 2.0mm and higher.
    Avid G3 is 2.30mm and the new XX floating is exactly at 2.0mm.
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    251 is offline
    Reputation: 251's Avatar
    Quote Originally Posted by Zachariah
    .. the new XX floating is exactly at 2.0mm.
    Have the current XX rotors been replaced with a floating design?
    Dave
    ^^I stand corrected...the XX rotors are still two-piece - not floating...my bad
