Results 1 to 3 of 3
    Jan 2005
    Rotor size for '04 Marathon SL
    I'm looking to go disc, probably Magura Louise (not FR). Is there a size limit for the front rotor for my '04 Marzocchi Marathon SL fork? I thought I read something about 160mm being the limit. Anybody know?
    Reputation: lebikerboy's Avatar
    Jan 2005
    You're correct on the size limitation. Here it is direct from the Marzocchi website:
    Which disc brakes can be mounted with the Marzocchi forks?
    All the Bomber models with legs of 30 mm diameter can mount discs until 6"(160mm), all those with legs of bigger diameter discs until 8"(203mm).
    Quote Originally Posted by riftdrift
    Jan 2005
    Thanks.
  1. Marathon SL Leaking Negative Chamber
    By gearz in forum Shocks and Suspension
    Last Post: 12-22-2004, 11:43 AM
  2. 29er or 26er Marathon SL '04 & Stratos ID cartridge?
    By EPO in forum Shocks and Suspension
    Last Post: 11-08-2004, 04:05 PM
  3. Marzocchi Marathon SL air setting for 150lb rider?
    By dawgcatching in forum Shocks and Suspension
    Last Post: 10-01-2004, 09:35 PM
  4. Tried a Marathon SL the other day
    By Stevebiker in forum Shocks and Suspension
    Last Post: 09-22-2004, 09:08 PM
  5. Marzocchi Marathon SL and Z1 FR SL-same internals: same performance?
    Last Post: 05-25-2004, 02:50 PM
