Results 1 to 3 of 3
    Reputation: bigdrunk's Avatar
    Rotor Rub on New Louise FRs
    I just installed a set of 2004 Louise FRs. Ithe caliper is spaced to where the rotor is going right down the middle. One of the pads is rubbing very hard. When I look down the rotor, I can see daylight between the pad and the rotor that isnt rubbing. On the one that is, obviously no light between.
    When I pull the lever, the non rubbing pad moves into contact with the rotor, while the pad with the rubbing problem does not seem to do much. When I release the lever, the non rubbing pad contracts, while the one that rubs, doesnt budge.
    What could the problem be?
    Reputation: The Squeaky Wheel's Avatar
    More fluid is trapped in one piston than the other.
    Easy to fix.
    Using a rag and two hands, push the rotor over to the piston that's closer to the rotor. Hold it there with one hand (or it helps to have a second person) and squeeze the lever once or twice. This will force fluid into the piston that's further from the rotor & will even things out.
    Sometimes it over corrects and then you have to do it in the other direction.
    Ted is offline
    Ted in real life
    Reputation: Ted's Avatar
    Similar Sort of Fix
    I used a business card. With the pads pushed back I placed it between the rotor and caliper on the side that was too close. I then squeezed the lever several times to adjust the pads. Then removed the card. The rotor was then centered between the pads.
  1. Magura Louise FR adaptor question
    By SuperBad in forum Brake Time
    Last Post: 03-09-2004, 02:38 PM
  2. Magura Louise FR Line Cutting Question
    By toonces in forum Brake Time
    Last Post: 03-08-2004, 08:03 AM
  3. Louise FR
    By jimbo2k in forum Where are the Best Deals?
    Last Post: 03-06-2004, 10:30 AM
  4. Magura Louise Pad same as Louise FR Pad?
    By staz in forum Brake Time
    Last Post: 03-06-2004, 08:31 AM
  5. Trade louise or Marta pads for Julies
    By Bert in forum Brake Time
    Last Post: 01-23-2004, 10:26 AM
