Results 1 to 2 of 2
    Rotor Replacement Suggestions
    I have a Trek Fuel EX8...One of my rotor's is warped so it is impossible to get a good pad adjustment. It currently has Avid G2 CS's on it. Anyone have a suggestion for a better rotor or should I just get the G3. I need 185mm.
    I would go the G3, or the cleansweep X version if you want to be a bit more fancy. Either one has a lot more power than the G2.....in fact replace both rotors if you can afford it.
