Results 1 to 6 of 6
    Rotor recomendations
    My bike is equipped with Shimano SLX brakes and I need to replace the rotors. Should I stay with Shimano brand rotors or are there better options?
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    There are certainly some better options out there, but the question is whether or not there is any significant improvement in performance. My gut tells me . . . . no. Unless you're not happy with the shimano's, then just get them again. In terms of power/performance, you'll notice bigger differences when swapping pads.
    Why do you need to replace the rotors?
    THanks for the reply. I think I'll stick with the Shimano rotors. All of my old bikes had Avids and I loved them compared to the SLX brakes but I think a big part of that is because they had larger rotors. I am thinking about going to 180mm on the front. I need to replace one of my rotors because it took a hit and got bent.
    Big Test Icycles
    Reputation: Hangtime's Avatar
    I run Avid HS1 rotors with my SLX brakes. They work pretty well and are lighter than the Shimano rotors.
    I've had good luck with the avid clean sweep rotors and the alligator windcutters
    Re: Rotor recomendations
    Get slx rotors. They are amazing compared to the g3s they replaced 185/160, slx are 180/160) this is using deore m596s no.doubt felt a difference.
    Sent from my HTC EVO LTE
  1. Replies: 9
    Last Post: 04-01-2012, 12:18 PM
  2. Replies: 9
    Last Post: 12-29-2011, 05:47 PM
  3. Replies: 1
    Last Post: 12-05-2011, 02:41 AM
  4. Replies: 39
    Last Post: 05-25-2011, 06:14 PM
  5. Need rotor advice from Marta SL/storm rotor users
    By Shuteye in forum Brake Time
    Last Post: 02-14-2011, 02:58 PM
