Results 1 to 2 of 2
    Reputation: bhutata's Avatar
    Rock Shox disc rotor with different calipers?
    I have a NOS White front hub made for Rock Shox disc that I'm not sure what to do with. My bike only has disc mounts on the fork anyway, so I fishing for ideas and thinking about putting disc on the front and leaving my V-brake on the back. If I buy a Rock Shox 165mm rotor, could I use it with a different manufacturers caliper?
    Also, if I do this, should I buy an extra rotor or two while I have the chance while they're available and cheap?
    A man is only a man, but a good bicycle is a ride.
    Not a regular
    Quote Originally Posted by bhutata
    The White hub with the 3-bolt rotor mount hole has the same rotor mount diameter as any 6-bolt rotor. So you can mount any 6-bolt rotor on your 3-bolt hub - I did it at one time. But - and here's the kicker - the offset for the rotor on your White hub does not match any current caliper spacing. In other words, the rotor sits futher away from the locknut / end cap of the hub than all current brakes do. If you really want to do it, you'll need to space your caliper in a few millimeters to get it to sit over the rotor on your White hub.
  1. Rock Shox Discs?
    By Threesticks in forum Brake Time
    Last Post: 03-18-2004, 08:00 PM
  2. rock shox: rear shock sid model year 2000
    By teo in forum Shocks and Suspension
    Last Post: 03-11-2004, 01:16 AM
  3. Rock Shox '05 info
    By angryasian in forum Shocks and Suspension
    Last Post: 03-03-2004, 02:08 PM
  4. Rock Shox Psylo
    By Kevin in forum Downhill - Freeride
    Last Post: 02-02-2004, 03:51 AM
  5. XTR hubs/rotors with other disc calipers?
    By coolhandluchs in forum Brake Time
    Last Post: 01-23-2004, 03:23 PM
