Results 1 to 8 of 8
    Ripped front brake line?
    fool goin up, joker down
    Jan 2009
    Yeah all you need to do is replace the cabling good luck!!
    Mamma speed I'm back!!!
    Dec 2008
    You may not need to replace the cable. Those are cantilevers, you need to find the metallic part that connects the vertical cable to the horizontal cable. It's a tiny metallic part.
    Dec 2008
    The part is not expensive, but it may not be easy to find. The cantilever brakes are an old brake type.
    Reputation: vk45de's Avatar
    might be cheaper just to get Vs
    Never enough time to ride
    Reputation: squish's Avatar
    Most shops should have the wire carrier for right around $3.00 or so, and a new cable should run between $3.00 and $5.00. Your straddle cable looks okay, so tops $10.00 unless you have the shop do it then probably right around $15.00 to $18.00 depending on labor rate.
    happy trails...
    squish
    Get out and ride!
