Results 1 to 5 of 5
    Reputation: Franco94's Avatar
    Ripped the brake line out of the caliper - help!
    I caught this huge stick today in the front wheel and somehow managed to rip the brake line out of the caliper. Fluid gone - hose won't go back on.
    I have Hayes HFX9 hydro brakes. Do I need to replace the brake line or should I just buy a new system for the front ($120)? I've never had a problem in 3 years with these brakes so I'm sort of a newbie to this issue. Your thoughts are appreciated.
    Meh.
    Reputation: XSL_WiLL's Avatar
    Did you just rip the hose out of the fitting? Or did you tear the fitting out of the caliper? If the latter, were the threads damaged?
    A new line and bleed is like 30 bucks if that's all it needs.
    Fitting Ripped in half
    I believe the best way to describe it is that I ripped the fitting in half. The metal half is still in the caliper and the hose comes free. It makes sense to me now that a hose could be replaced. Where do you find compatible parts? I'm guessing I'd need something specific to Hayes HFX-9.
    Brake pic
    Here is a pic of the situation
    Meh.
    If fluid got on your pads, you'll need new pads too.
    Right, you can just get a replacement hose from Hayes, or you can do something fancy like a braided hose from Jagwire, Hope, Galfer, Goodridge, etc.
