Results 1 to 8 of 8
    Checkin' it out
    Retracting pistons ...
    What's the best way to retract the pistons after changing the pads? I used the screwdriver method wedging the old pads back and forth, but it didn't work. I tried the FAQ, couldn't find an answer. Besides using the screwdriver, what's a better method? Thanks for all the help!
    Nov 2007
    Quote Originally Posted by 1996Marin View Post
    A screwdriver inevitably pushes the pistons back unevenly.if they get tipped off axis they jam, as you have found out. Usually you can get the screwdriver thing to work if you can get at the caliper from both sides.
    If you remove the old pads you have to be more careful in case you damage the pistons. The damage comes if you get the pistons off axis and carry on forcing them back.
    Inserting an allen key of appropriate size all the way through
    With the flats facing the piston and then rotating it gives a controlled way of nudging back the pistons a short distance at a time.if any significant force is required then something is wrong.
    Brakes using dot fluid often end up with more fluid volume because of water absorption. In this case, the pistons won't push back and stay back without venting some fluid from the master cylinder.
    Sent from my GT-I9100 using Tapatalk
    Jul 2003
    Best method I've found is to use a small box end wrench to push the pistons back into place. The rounded edges of the wrench won't damage the piston face and tend to apply force evenly. Remove the old pads, push the pistons back in completely, install the new pads. Re-install the wheel and pull the lever a few times to reset the pistons.
    As petercarm noted, if you can't get the pistons to stay fully seated, or they pop back out a bit, you may have to vent a bit of fluid. Usually though, if the fluid has absorbed enough moisture to produce this problem, it's a good call to go ahead and bleed them. It won't be long before you'll have to anyway.
    Good Dirt
    May 2010
    I have a 6" length of S/S plate, ~ 1mm thick - ground a taper @ 1 end. Insert between pads & lever - done!
    Lots of pistons are phenolic resin, crumble like cheese if you lever on them direct (As I found out with my Juicy 7's...)
    greedy
    Reputation: have2ride2day's Avatar
    What brakes are they?
    Addicted to the Classifieds
    Plays with tools
    Reputation: customfab's Avatar
    pedros tire levers are perfect for pushing pistons back in. If you are having trouble pushing them back in might try cracking the bleed port and let the excess fluid out.
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Yup, I use a tire lever to span the piston and push if I can't fit my fingers in there (Hope's have a WIDE channel).
    Oct 2011
    never had any trouble with the screwdriver method, so long as you're careful and do it slow
  1. Pistons moving, but not retracting- what to do?
    By suicidebomber in forum Brake Time
    Last Post: 06-23-2010, 01:16 PM
  2. Avid Juicy 7 pistons not retracting
    By rshalit in forum Brake Time
    Last Post: 11-06-2006, 10:58 PM
  3. On of my pistons is not retracting (Formula)...
    By DoctorJD in forum Brake Time
    Last Post: 06-10-2006, 01:54 PM
  4. My XT pistons aren't retracting...
    By rzozaya1969 in forum Brake Time
    Last Post: 03-24-2006, 08:32 AM
  5. Caliper pistons not retracting ??
    By Air-Time in forum Brake Time
    Last Post: 03-16-2005, 09:50 PM
