Results 1 to 3 of 3
    Oct 2013
    Replacing hose on Shimano hydraulic brakes?
    I have some Shimano brakes. Not sure which model but mid-range. I moved them onto another bike but the rear hose wasn't long enough so I bought a Clarks replacement hose. I am having problems fitting the hose however. The brass fitment doesn't seem to fit over the hose even though it was supplied with it so it must be the right one. Is there any trick to fitting it on?
    Cheers
    Aug 2013
    You're probably referring to the olive. It is usually a bit loose, it will compress and form a tight seal when tightened. If that's not it, please supply a detailed description
    Oct 2013
    Quote Originally Posted by molsen234 View Post
    Yes it is the olive that I am referring to. This one is far from loose which is annoying as it was supplied with the hose. I guess I will just have to try and source another one from somewhere. Are the Shimano hoses much bigger than others?
  1. Jagwire HyFlow Avid vs. Shimano Hydraulic Hose
    By agentorangemen in forum Brake Time
    Last Post: 02-27-2016, 05:45 PM
  2. How do I Loosen M395 shimano hydraulic brakes.
    By Daniel Armstrong in forum Brake Time
    Last Post: 09-19-2013, 08:46 PM
  3. Replacing my hydraulic brakes.
    By C83L5oD in forum Brake Time
    Last Post: 05-15-2013, 03:33 PM
  4. Replies: 1
    Last Post: 05-02-2012, 07:02 AM
  5. Shimano XT hydraulic brakes
    By BORDERCOLLIE in forum Commuting
    Last Post: 09-30-2011, 08:18 AM
