    Oct 2012
    New question here. Replacing Hope M4 Pistons & Seals
    One of my pistons on my rear caliper is leaking a slight bit. I would assume its a seal and dirt got in there. Its on the side closest to the spokes. What tools do I need to service the caliper pistons? Is it wise to replace all pistons/seals or just replace the one thats leaking? I dont think I need the special tool to remove the borecaps since the leaky piston is on the opposite side.
    Also, according to Hopes website there is a authorized distributor in Texas. Anybody order from them?
    Pivoteer
    Reputation: tiSS'er's Avatar
    Quote Originally Posted by stumpynerd View Post
    Call Hope in Texas directly. The tool is like $16, and the parts are even cheaper. I had the same issue and replaced all 4 seals and pistons for like $25.
    Employed by Pivot Cycles - www.pivotcycles.com
    Oct 2012
    Any tips on replacing the pistons & seals?
    Pivoteer
    Its pretty easy. Remove the pads, and then hold the 2 outside pistons in place. Then pump the lever to push out the 2 inside pistons. Once those are our far enough to grab, pull them out. You can then use the tool to unscrew the caps, and push the 2 outside pistons out. Lube up the seals, and put the pistons back in. Screw the caps back on and bleed. Once you see it, it makes sense. Just be sure to get the 2 inside pistons out before you remove the caps and work on the outside pistons. Pretty simple once you see it.
  1. Replacing pads and resetting pistons on Elixir 5
    By gibsonlespaulspecial in forum Brake Time
    Last Post: 08-01-2013, 11:04 PM
  2. Replacing Fox Float R seals - issue with shock mounts
    By SpringsRubicon in forum Shocks and Suspension
    Last Post: 07-15-2013, 06:14 PM
  3. Fox f32 stiction after replacing seals...
    By kikoraa in forum Shocks and Suspension
    Last Post: 04-27-2013, 01:06 AM
  4. Fox F29 120 (fit) loose after replacing seals/fluids and damper oil
    By fish0281 in forum Shocks and Suspension
    Last Post: 04-14-2012, 10:44 PM
  5. Replacing all seals in Headshok Super DL80
    By qba in forum Cannondale
    Last Post: 05-20-2011, 05:42 AM
