Results 1 to 2 of 2
    Reputation: Eggman's Avatar
    Replacing Hayes Mag Lever Blade
    i am preparing to replace my lever blade and was wondering if anyone out there has done this. i don't think i need to disassemble the lever body, right? it seems from looking at it that i can just back out the hex nut that holds it to the master cylinder and unscrew the blade from the push rod, is that it?
    any tips on acheiving the "grab" distance you want? thanks!
    Quote Originally Posted by Eggman
    You will need two 2mm Allen wrenches (hex key wrenches) one to keep the lever pivot pin from turning and one to unscrew the bolt. This is for 2003 and later models, on 2000-2002 models the lever pivot pin is pressed in. On you model you will not need to remove the lever body, you can just unscrew the lever pivot pin (T-bolt) and unthread the master cylinder push rod.
    Erik,
    Balle Racing
    www.balleracing.com
  1. Hayes lever pull different front vs. rear
    By spacoli in forum Brake Time
    Last Post: 03-17-2005, 04:41 PM
  2. Replies: 2
    Last Post: 02-23-2005, 03:18 PM
  3. Replies: 1
    Last Post: 02-08-2005, 12:39 AM
  4. hayes mag - air lock - how do you fix this??
    By waukeetx in forum Downhill - Freeride
    Last Post: 10-23-2004, 09:50 AM
  5. Hayes Mag lever reach adjustement loose?
    By ptolar in forum Brake Time
    Last Post: 03-12-2004, 07:58 AM
