Results 1 to 8 of 8
    Darth Nader
    Reputation: Lighty_'s Avatar
    Sep 2003
    Replacement Rotors - what's the difference?
    I am shopping around for a replacement rotor for one that got bent. Is there any real difference among the diffrenet brand rotors, or specific after market ones like Aztec? I need a 6 bolt 160mm rotor, but beyond that is one rotor as good as another?
    BLOG: http://dirtyrubber.blogspot.com
    Latest entry: 06-13-2005 Annadel Ride
    "El Whatever"
    Reputation: Warp's Avatar
    Quote Originally Posted by Lighty_
    In cycling you get what you pay for. Cheaper cost usually means cheaper materials.
    Try to stick whit your manufacturer's products or with recognized brands.
    Check out Galfer, Avid and Hayes. Hayes specially makes quality cheap rotors.
    Check my Site
    I had a 180mm Aztec that was prone to warping. Much more so than the 180mm Magura I replaced it with.
    ...which brings me to my next topic: I have 2 New 160mm XT M756 (NON-centerlock) rotors that I'm selling for cheap. Email me if interested: mtbrpunk AT skiingismylife COM
    Wavy Rotors
    Anyone have a source for wavy rotors. Need 160mm for Avid Mech's.
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    Larry at Mtn High has Galfers & some others.
    mtnhighcyclery@attbi.com
    “Life is like riding a bicycle. To keep your balance, you must keep moving.”
    ― Albert Einstein
    I'll bump the galfer wavy rotor. Has been put through some punishment with no warping.
    I am pretty sure speedgoat carries them.
    "El Whatever"
    You should first read some opinions about wavy rotors around the forum. There had been some complain of weird noises and pulsing from Magura (Galfer) and Avids. Check out and make your own opinion.
    Avid has been known to be replacing wavys with round "clean sweep" ones.
    Check my Site
    Anytime. Anywhere.
    Reputation: Travis Bickle's Avatar
    Rotors
    I have a set of cheap after market rotors that I use on my heavy duty wheelset with Avid mechs. They work just as well as the expensive avid rotors but were cheap and can be had at MEC in Canada. I have been riding discs for 41/2 years and weigh 220, so if they work for me they'll work for you.
    http://www.mec.ca/Products/product_d...=1097871693196
    Pads are also cheap.
    http://www.mec.ca/Products/product_d...=1097871693200
    Bear in mind that these prices are in Canadian dollars.
    I got some bad ideas in my head.
  1. Up-sizing Shimano XT rotors to 180 or 200 mm
    By Dave99 in forum Brake Time
    Last Post: 09-22-2004, 12:36 PM
  2. Replies: 1
    Last Post: 08-17-2004, 06:54 PM
  3. Best pricing for replacement Avid 160mm rotors?
    By rglsr in forum Where are the Best Deals?
    Last Post: 08-17-2004, 11:25 AM
  4. Ceramic coated discs?
    By Tony Montana in forum Brake Time
    Last Post: 03-17-2004, 07:21 AM
  5. Help w/ replacement rotors for Avid Mechs
    By ThornPatch in forum Brake Time
    Last Post: 02-03-2004, 02:23 PM
