Results 1 to 3 of 3
    New question here. Replacement Pads for XT discs.
    I need new pads for my XT's, the pre '04 model.
    I currently have stock metal pads.
    Which replacement pads shoould I get?
    - Shimano OEM ( Metal or resin? whats the difference in performance?)
    - Koolstop
    - EBC (which compound works bes?t)
    - Clarks (Carbon-Lorraine)
    I will use then on a 10kg (22lbs) hardtail so stopping power isn't the priority as the brakes have enough of it. I am looking for: (in this order)
    - Fade resistance
    - Quite pads
    - Long life
    Thanks,
    Patryk
    Reputation: Fat Elvis's Avatar
    I've got the same brakes
    and am currently using the stock sintered metal pads. I get some squeal like everyone else seems to get. I've heard that the EBC GREEN pads are very good, but have never tried them myself
    Reputation: Wombat's Avatar
    On my XT with 200mm rotor up front I have used the originals and the EBC greens and are trying the gold (so far only on the rear) at the moment. I think the originals lasted longest, but the greens were fine with little noticeable difference in stopping or modulation. Price was the main difference. I haven't noticed any real difference with the golds on the back.
    The only disappointing thing about the after market pads was that I lost the very slight singing noise (almost as if a blade of grass was flicking through the rotors) that the originals made.
    Wombat
  1. Avid discs pads clattering
    By dllewell in forum Brake Time
    Last Post: 06-04-2004, 11:56 AM
  2. Aztec pads for Avid discs: Extreme Danger!
    By tscheezy in forum Brake Time
    Last Post: 05-03-2004, 04:59 PM
  3. metal vs. resin replacement pads
    By beekeeper357 in forum Brake Time
    Last Post: 02-14-2004, 03:55 PM
  4. Replies: 4
    Last Post: 02-12-2004, 10:55 AM
  5. Replies: 1
    Last Post: 02-07-2004, 11:21 PM
