Results 1 to 5 of 5
    May 2012
    Replacement Magura clamp bolts?
    Hey guys,
    I have Magura MT4 brakes and recently had to loosen the clamp bolts so I could adjust the lever to a 15 degree angle for bleeding, however when I tried to loosen the bolts one of them stripped almost completely and so it cannot be undone properly and the other one snapped clean off
    Looks like I'll have to use a drill to try and get the remainder of the bolt out
    I used a brand new T25 X-Tools tool but somehow still managed to ruin two bolts so I'm wondering if they're any alternatives, perhaps steel bolts?
    I really don't want to pay 16 for a pack of 10 awful bolts from Magura.
    any suggestions guys?
    Thanks.
    On your left.
    At least on the MT6, those are custom nuts which are removed, there is a threaded stud permanently installed in the lever. If you damaged the custom nut, you'll have to get that from Magura - maybe ask JudeMonica here for free parts ;-). If it's the threaded stud, I have no suggestions, definitely requires Magura service.
    M
    May 2012
    Quote Originally Posted by Motivated View Post
    Yeah it looks the same as the MT6's from what I can tell.
    I need the custom nuts, not the threaded stud (Thankfully).
    Who's JudeMonica, a Magura rep? and how do I contact him/her?
    Thanks.
    Reputation: drbelleville's Avatar
    Jude, is the Magura rep and I sent you his E-mail via PM.
    He does a great job at supporting Magura customers.
    May 2012
    Quote Originally Posted by drbelleville View Post
    Awesome thanks mate, much appreciated.
  1. Replacement bolts
    By fotooutdoors in forum On One
    Last Post: 11-14-2012, 02:54 PM
  2. Stem/Steerer Clamp bolts loosen
    By Adroit Rider in forum Tooltime
    Last Post: 08-28-2012, 07:24 PM
  3. Magura MT8 and Matchmaker Clamp
    By Alexgonzalezmi in forum Brake Time
    Last Post: 02-02-2012, 02:34 PM
  4. Rocker Alu Bolts replacement
    By anvil_den in forum Titus
    Last Post: 10-18-2011, 01:23 AM
  5. replacement stem bolts
    By TheBigV in forum General Discussion
    Last Post: 09-01-2011, 07:47 AM
