Results 1 to 2 of 2
    replacement brake lines for shimano xt785
    I managed to pop the front brake line on my new XT785 brakes. Any opinions on the best replacement, and or what I need to replace\bleed them? I've been mtn biking for 25 years and this is my first set of hydrolic brakes.
    jagwire, goodridge. you would have to remove old line, cut new one to length (use a brake line cutter) install and bleed. shimano are super easy to bleed, I like to push fluid up through the caliper with a syringe into the lever.
