Results 1 to 9 of 9
    replaced pads, now rotor won't fit
    Replaced pads in Avid Elixir CR brakes. Pried pistons apart, took out old pads, put in new ones, pried them apart more/again, and couldn't get the rotor to fit in the clearance b/w the new pads. these brakes have a "contact" adjustment at the lever, dialed it all the way out. managed to get the rotor in but the brakes just drag, they're totally tight.
    From the look of it the pistons are fully recessed, but I guess they must not be?? I have no idea what to do other than head to the LBS. Any suggestions????
    Thanks.
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    The pistons are not fully retracted- they need to be flush with the caliper. Two suggestions: use a 3/4" or 19mm wrench to pry them apart further (remove the new pads, use the box end and place the edge of it inside the caliper and position on the middle of one of the pistons and pull the wrench in the opposite direction; then do the same on the other piston) or use a large flat blade screwdriver (reinstall the old pads, insert screwdriver in between the pads and gently turn the handle back and forth).
    yeah what he said....
    I'm just messing with you
    Reputation: wv_bob's Avatar
    My elixirs came with a red plastic "wedge" thing that jams between the pads to spread things out.
    In the photo at the following link, the thing I'm talking about is smack dab in the middle
    Universal Cycles -- Avid Professional Bleed Kit
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Quote Originally Posted by wv_bob View Post
    Exactly . . . one of these: AVID ELIXIR Pad Spacers/ Bleed Blocks Biscuits LIKE NEW | eBay
    Use those with your OLD pads in place to push the pistons back in place most of the way. Then put the NEW pads in and repeat which should push them ALL the way back in.
    ^ Why would someone pay for something so elementary like that?
    007 is offline
    b a n n e d
    Jun 2005
    Quote Originally Posted by the-one1 View Post
    Because they lost the one that came with their brakes?
    I have serviced my pads also - found this tool is excellent for pushing in the pads - its worth it if you can service your own brakes. - Park Tool Co. » PP-1 : Hydraulic Piston Press : Brake Tools
    Amazon has it for 14 bucks...
    Reputation: RustyIron's Avatar
    If you have excessive fluid in the system, you might need to crack the bleed screw on the caliper, so it will allow some fluid to escape as you pry the pads apart. Be careful not to get any fluid on the new pads.
  1. When should disk pads be replaced?
    By glouden in forum Brake Time
    Last Post: 08-14-2011, 06:33 AM
  2. When to know if a rotor needs to be replaced...
    By rzozaya1969 in forum Brake Time
    Last Post: 04-19-2011, 04:40 PM
  3. Replaced brake pads and F##K!
    By rydbyk in forum Brake Time
    Last Post: 07-15-2010, 08:45 PM
  4. Just replaced pads in my Codes
    By Tree in forum Brake Time
    Last Post: 04-12-2007, 07:53 AM
  5. Just replaced my pads, now rotors rub
    By TeddyBallGame in forum Brake Time
    Last Post: 04-04-2007, 06:19 AM
Members who have read this thread: 4
